RX-A2020 qiestion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-30-2012, 05:40 AM - Thread Starter
BobChiz's Avatar
I was told when I bought the unit i could watch tv in one room and listen to music in another at the same time.with the zone feature I don't see it is the set up menus.this is the main reason I bought it.
BobChiz is offline
post #2 of 2 Old 12-30-2012, 06:24 AM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
On the remote at the top you should see a selector switch. Toggle it to second zone press the power button and select your source. I don't remember anything specific in the setup I did to allow this other than setting the amp part in the settings menu. These new receivers are so feature packed that the old way of doing things (not reading the manual) are long gone. I have gone back several times to reference specific features of these units. BTW I have the 1010 so I hope this helps.
Good luck.
RTROSE
RTROSE is offline
Yamaha Rx A2020 9 2 Channel Network Aventage Av Receiver
