Emotiva XPA-2 or XPA-5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-30-2012, 05:03 PM - Thread Starter
Scott Andersen's Avatar
I use my system mainly for home theater use. I am looking to get more out of my sister. Which amp would you recommend starting with, the xpa-2 or xpa5? I plan to get both at some point and upgrade to a 7.1, but if you could choose just one now what would it be?
2 Polk Audio RTI 12s
Polk Audio CSI A6 center
Polk audio 2 FXI A6 rear surrounds
Pioneer sc-1222k receiver
Polk audio psw505 subwooofer
Scott Andersen is offline
post #2 of 10 Old 12-30-2012, 05:27 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
I don't think you are going to gain anything by getting dedicated amplifiers for all channels with the gear you already have. The only speakers that might benefit from dedicated amplification are your front mains. If you use an 80hz crossover for the mains then I don't think an XPA-2 would make much of an improvement. If you listened to music a lot and crossed the mains over lower then it might be something to consider. One thing I would consider is your subwoofer. You main gain more by investing in a better subwoofer or going with multiple subwoofers. There are a few questions you need to answer first. Why do you think you need more power with the current set up? How large is your room and how loud do you listen? I currently own an XPA-5 and a pair of XPA-1's. I used to own an XPA-2. They're nice amplifiers.
Secret Squirrel is offline
post #3 of 10 Old 12-30-2012, 08:52 PM - Thread Starter
Thank you for your advice. If I had a budget of 1,000 what subwoofer would you recommend? The room is 14ft by 18ft. I don't necessarily like to listen too loud often, but I want legit bass that will shake the floor. Any advice?
post #4 of 10 Old 12-30-2012, 08:53 PM - Thread Starter
Originally Posted by Scott Andersen View Post
Thank you for your advice. If I had a budget of 1,000 what subwoofer would you recommend? The room is 14ft by 18ft. I don't necessarily like to listen too loud often, but I want legit bass that will shake the floornwhen watching movies. Any advice?
post #5 of 10 Old 12-30-2012, 09:13 PM
Quoted: 44 Post(s)
Liked: 39
There's a lot of choices for subwoofers. Bic has some good performing affordable subs. SVS and HSU also have nice subwoofers. There are also more good brands of subs, you can find a lot of good information in the subwoofer forum.
post #6 of 10 Old 12-30-2012, 09:28 PM
Acuramusic42's Avatar
In that price range check out http://www.powersoundaudio.com/ . Power Sound Audio is a new company by Ex SVS employees. You can email Tom at the online web site. He is the owner and can answer questions related to your particular setup. I just got the XV-15. It provides excellent sound. I paired it with the Velodyne DLS 4000R. Tom is known to answer email personally and quickly.
Onkyo TX-NR5009, Emotiva XPA-2 & XPA-5, Oppo 103D Blu-Ray Player, Marantz 6004 CD, Teac V 670 Cassette Player, Pioneer CLD-D704 Laser Player, JVC HM-DH3000U VCR, Technics SL1200MK2 Turntable, Belkin PF 60 Power Conditioner, Comcast Infinity X-1 MO MX011ANM, XBOX 360, 2 PSA XV-15se Subs, Chane A5rxc Main and Chane A2rxc Center Speakers, Infinity SS 2002 Side Speakers, JBL Studio 220 Rear Speakers, BIC DV 62si Height Speakers, Sony 43X830C TV. Harmony One.
Acuramusic42 is offline
post #7 of 10 Old 12-31-2012, 01:18 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
+1
jbrown15 is offline
post #8 of 10 Old 12-31-2012, 06:10 AM
Quoted: 44 Post(s)
Liked: 39
+2 on checking out the XV-15 from Power Sound Audio.
post #9 of 10 Old 12-31-2012, 07:07 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Powersound is a good option. The XV-15 for $799 shipped is a good deal. I personally, would look at the hsu VTF-15H, It will cost around $1,040 with shipping for the standard black one. For $100 more, you can get rosewood.
KidHorn is offline
post #10 of 10 Old 12-31-2012, 11:44 AM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1324
Rythmik also makes excellent subs for around $1k...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Emotiva Xpa 5 5 Channel Power Amplifier
