VSX-521k & Mirage OMD-15's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-30-2012, 11:17 PM - Thread Starter
Oppywan's Avatar
First off, hello, everyone! First post.
I was wondering what your thoughts are on whether or not the Pioneer VSX-521k receiver is powerful enough to effectively drive the Mirage OMD-15 floor standers as fronts in a 5.1 set up.
I know it probably isn't idea power output, however, I just was looking for affirmation that this AVR won't be clipping or otherwise severely under-powering these somewhat more hungry speakers than I usually run- I'm slowly upgrading my speaker system piece by piece.
Just want to make sure I won't be putting the speakers at risk due to underpowering them or overloading the receiver, since they are rated as 6ohm nominal (4ohm min) and slated for 25-250 watts.
Also, would there be any issues with the fact the fronts would be 6ohms resistance, while the CC and surrounds are all 8ohm?
Thanks for any input!
Oppywan is offline
Pioneer Vsx 521 K 5 1 Home Theater Receiver Glossy Black
