Emotiva XPA-5 or Parasound A51 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-31-2012, 08:25 PM - Thread Starter
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Just wondering whether anybody have tried them both and have any opinion in the sound quality between the two (well, which one is better, or are they just different).
Thank you very much beforehand.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #2 of 14 Old 01-01-2013, 12:47 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Well, the A51 is High Bias A/AB, the emo is only AB. Meaning at low volume the A51 is pure class A.
I personally would not waste my money on Emo.
The A51 will produce a better soundstage, imo.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 14 Old 01-01-2013, 01:06 PM
Theresa's Avatar
Liked: 51
Don't believe marketing hype like "High Bias A/AB" without double blind tests to prove it is actually something that can be heard. The money spent on a Parasound amp is almost always better spent on room treatments and speakers. All "AB" amps operate in class "A" up to a certain point as do all competently designed amps. The Emotiva amps all have vanishingly low distortion which can be seen by the independent tests they publish on their site.
Theresa is offline
post #4 of 14 Old 01-01-2013, 02:43 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5069
+1. What does "High Bias A/AB" even mean?
There is also the issue of "The A51 will produce a better soundstage" too. How on earth does an amp "produce a soundstage"? Where has that come from?  If it is from the marketing literature of the amp manufacturer, then I would be highly skeptical about anything else in that literature too as the idea that an amp can influence the soundstage in any way is pure BS*. Just sayin'...
And, of course, you are 100% right about spending the money saved on better speakers and/or treatments. That's where the biggest SQ improvements will be heard - not in some alleged differences between amps.
EDIT:
*Just for the sake of completeness it is perhaps worth mentioning the Bob Carver patented 'Dimensional Sound Producing Apparatus' where Carver does claim to be able to 'enhance' stereo imaging by deliberately introducing a delayed and equalised signal in both (stereo) speakers. AFAIK this technology has never found its way into a modern SS amplifier and is, in any case, a deliberate distortion of the input signal. I can't recall the precise details of how it worked, but google will find "Dimensional Sound Producing Apparatus" I am sure, for anyone interested in reading more.
kbarnes701 is offline
post #5 of 14 Old 01-01-2013, 02:49 PM
kbarnes701's Avatar
Liked: 5069
Modern solid state amps, when working within their design parameters (eg not clipping) have been shown in numerous blind ABX tests to be indistinguishable in sound quality. If the amps under consideration are powerful enough to drive your speakers to the desired levels, without clipping, then the cheapest is the one to go for (assuming decent design / build quality, which the Emo amps have in spades).
Here is a page of links to various blind tests:
http://www.head-fi.org/t/486598/testing-audiophile-claims-and-myths
post #6 of 14 Old 01-01-2013, 03:36 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
Considering I'm in Canada, how difficult is it should I need to fix the power amp? will Emotiva pay for shipping both ways? I'm asking this because to ship the Emotiva registered with tracking and signature-required will cost me near half the price of the power amp itself.
my home theatre
post #7 of 14 Old 01-01-2013, 05:57 PM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Biased in that it may operate class A for the first 5 watts instead of first 2 watts.
Class A's technical merit is that while in Class A you aren't building the wave form with two banks of transistors which it not designed properly can introduce cross over distortion. On the Stereo imaging and soundstage side as long as your channel crosstalk is they will both image well.
I ran Parasound, I ran Adcom. Surprisingly enough I now run 'Pro-Audio' gear: Crown. My XLS402D is a better amp than my two Parasound HCA-1000's. Where the Parasounds were a bit noisy the Crown is Ink-black.
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #8 of 14 Old 01-01-2013, 06:30 PM - Thread Starter
Quoted: 612 Post(s)
Liked: 584
Well, Crown amps are widely used by THX commercial theatres worldwide but Parasound are also currently being used at Skywalker Sound.
my home theatre
post #9 of 14 Old 01-01-2013, 07:44 PM
gostillerz's Avatar
If the goal of home theater is to accurately replicate the theater experience, wouldn't it make sense to use the equipment the theaters use? They're not using $20,000 monoblocks, they're running pro audio stuff.
It's these cans! He hates these cans!
gostillerz is offline
post #10 of 14 Old 01-01-2013, 09:04 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
That is an interesting point. Class D may be great for HT and TV where dynamics are more important. If music is less important that may be a very good option.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is online now
post #11 of 14 Old 01-01-2013, 09:07 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
I also know Parasound is used at a high end sub woofer company to power the speakers they use for R&D to blend their subs with.
If music is a big part, tough to beat the Halo series.
post #12 of 14 Old 01-02-2013, 09:08 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
All I know is three years running I offered up my Parasounds to anyone that wanted to come by and blind tell me if they were listening to them or my Crown on my Statements. It was a 10 flips of the coin. Take a guess how many people I had take me up on that offer.
The XLS402D is one competent AMP IMO. Check out the New amp is making me grin from ear to ear thread
Also Home Theater Equipment has a Crown XLS DriveCore thread (Where Parasound was also removed to make room for Crown).
Jinjuku is offline
post #13 of 14 Old 01-03-2013, 11:46 AM
palmharbor's Avatar
I HAVE THE UPA 5 Emotiva power amp and I could not be happier. Their warranty is terrific....a floor installer moved my large cabinet and tore off the speaker terminals
and they replaced them no charge and paid for the Fed Ex charges. The Amp drives my Martin Logans wiithout a problem as my last power amp went into fault with
the ML.
I cannot recommend them more..plus telephone tech support is easy, complete and always available.smile.gif
palmharbor is offline
post #14 of 14 Old 01-04-2013, 05:52 AM
kbarnes701's Avatar
Liked: 5069
I am in the UK. For warranty Emo will only pay one way IIRC. But they will work with your local repair shop to help diagnose the problem and then ship parts directly to them. I have never had a problem with any of my 4 Emo amps and I am of the view that if the amps work OK for the first week they will probably be OK for years. Amps are fairly simple devices so the local shop should have no problem fixing a faulty unit, using Emo's spares.
Emotiva , Parasound , Emotiva Xpa 5 5 Channel Power Amplifier
