Need some help upgrading from 5.1 to 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-01-2013, 11:54 PM - Thread Starter
aftcomet's Avatar
Quoted: 53 Post(s)
Hi all. I have a Pioneer VSX-820-K. It is currently setup as a 5.1. I remember reading in the manual that it can do 7.1 through the use of an external amp. This is the manual:
http://www.pioneer-mea.com/en/manuals/1270025712VSX-820-K.pdf
It is on page 16.
I'm looking for a relatively low cost amp that will drive the speakers the same way as if the receiver was already 7.1 without pre-outs. Or maybe it's not worth it to add two speakers at all? My room's dimensions are 16.5 x 13 x 7. (It's my basement).
Suggestions or ideas?
aftcomet is offline
post #2 of 7 Old 01-02-2013, 02:03 AM
sdurani's Avatar
Quoted: 4482 Post(s)
Liked: 2904
If your seating is a few feet away from the back wall, then you're a good candidate for a 7.1-speaker layout (a pair of speakers directly to your sides and another pair spread out behind you). However, if your seating is at or near the back wall, then better to stick with a 5.1 layout (no space behind you for the rear speakers).
Not sure what your idea is of "relatively low cost", but 2-channel amps can be had for not much money: http://amzn.com/B0052CHIYC
Sanjay
sdurani is online now
post #3 of 7 Old 01-02-2013, 02:48 AM - Thread Starter
aftcomet's Avatar
Quoted: 53 Post(s)
Thanks for the reply. Yes, I will be sitting away from the wall about 3-4 feet. And by relatively low cost I mean something like you posted, if not even cheaper. I bought my receiver for $280. I've seen amps cost around $1000. Rather not even think about that much. If you could recommend something from a Canadian retailer as that's where I'm at.
aftcomet is offline
post #4 of 7 Old 01-02-2013, 03:03 AM
pokekevin's Avatar
Liked: 102
+1. Not worth it to have 7.1 when you are sitting pretty close to the back wall. Trust me, I didn't take his advice originally and boy was that a waste of time and money.
pokekevin is offline
post #5 of 7 Old 01-02-2013, 03:09 AM - Thread Starter
aftcomet's Avatar
Quoted: 53 Post(s)
So 3-4 feet is too close?
aftcomet is offline
post #6 of 7 Old 01-02-2013, 03:11 AM
pokekevin's Avatar
Liked: 102
I'm sitting about a foot away. At first 3-4 feet does seem close but one of my friend's set up I believe is pretty close to the back (I think) and still sounds awesome. Sdurani knows who I am talking about. He can comment on that
post #7 of 7 Old 01-02-2013, 12:41 PM - Thread Starter
aftcomet's Avatar
Quoted: 53 Post(s)
So assuming I get it, I have a few questions about the amp. Will it turn off/on automatically? What about the volume? Will I have to change it separately on the amp when I do on the receiver? The VSX 820 says it has 110 Watts of power per channel. Does this mean I need an amp that has 110W/channel as well? How difficult will it be the balance and match the sound to as if the Receiver was already a 7.1?
aftcomet is offline
