Looking for a receiver upgrade - AVS Forum | Home Theater Discussions And Reviews
Old 01-02-2013, 08:43 AM - Thread Starter
mudfrog's Avatar
Quoted: 21 Post(s)
I currently have an Onkyo TX-NR509 and while it's been a good little receiver I'd like to upgrade to something a little more powerful with more features. I have a few requirements. It needs to be at least 7.2, convert composite / component to HDMI and have an auto config similar to Audyssey and at least 100w per channel (preferably higher). The more HDMI inputs the better as well.
My speaker setup is:
Polk Audio CS2
Polk Audio Monitor 70's
Polk Audio Monitor 30's
(Will add Monitor 40's to complete the 7.x setup)
BIC F12
They aren't the most high end speakers but I do believe they will benefit from a little more power (I do not plan on using external amps with this setup).
So giving a price range of $400 - 700, possibly a little higher if it will really benefit the HT, what would be a good receiver? I'm open to different brands but I've used Onkyo in the past. I was eyeballing the Onkyo 809 which can be had for a little over $600.
Equipment - 60" Vizio M60-C3 - Denon AVR-2300W - Pioneer BDP-150 - HTPC, Xbox One - Sennheiser RS170 Headphones - APC C25B Power Filter
Speakers - SVS Prime Center, Bookshelves, Satellites, Dual BIC F12 12" Subs
HTPC - Intel Core i3-3220, 8GB DDR3 1600, 750ti 2GB, 7TB of HDD's, LG Bluray
mudfrog is online now
Old 01-04-2013, 01:09 AM
KingGiant's Avatar
I used to be an Onkyo guy too but I have noticed the brand has slowly gone downhill in comparison to the other big players. Onkyo still makes some nice receivers but I hear more people complain about their Onkyo's going out than any other brand.
Personally, I can recommend 2 receivers, as I have owned both.
The Pioneer Elite VSX-60 $649
The Pioneer Elite SC-61 $1100
I mention the 61 because it can be found on sale, I just bought mine for $849 after haggling with the Magnolia guy. The new Elite line has a few benefits, mainly the new amp designs. The 60 will really push some fantastic sound through your Polks, and it comes with the latest version of MCACC.
If you want a receiver that will set you up for the forseeable future than the 61 is a no brainer since it comes with a D3 amp. Finding a D amp receiver under $1000 is hard enough, let alone Pioneers newest D3. I'm running the latest MartinLogan Motion series speakers, and the 61 pushes wonderful, warm sound through my 5.1. I have not talked to a single professional installer that has anything negative to say about Pioneers new SC line.
If you plan to stay with 8 ohm speakers than the 60 would be the way to go, even though it produces 90 watts per channel. Plus the 3D pass through and air-play are nice touches. Lastly the the Pioneer processes the low frequencies much better and cleaner than the Yamaha line, if you are considering that brand as well.
My 2 cents.
KingGiant is offline
Receivers Amplifiers , Onkyo Tx Nr809 , Polk Audio Monitor Series Cs2 Center Channel Speaker Single Cherry , Polk Audio Monitor 70 Am7025 B 3 Way Floorstanding Speaker Single Black , Polk Audio Monitor 30 2 Way Bookshelf Speakers Pair Cherry , Polk Audio Monitor40 Series Ii Two Way Bookshelf Loudspeaker Cherry Pair
