If buying new receiver, can speakers from my HTIB be used until I upgrade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-02-2013, 03:55 PM - Thread Starter
CMonMan's Avatar
Liked: 34
Hello, In the living room area, I've got the Samsung HT-D6730 HTIB like this:
http://www.amazon.com/Samsung-Electronics-HT-D6730W-Theater-System/dp/B004OCN6ZG
It uses proprietery terminals/plug-ins for the speaker wires on the back of its "receiver".. I am wondering if I were to invest in a decent onkyo/denon receiver, would I be able to cut the ends off and use these speakers reliably until I am able to upgrade the speakers themselves? Not doing this in the near future, but would like to know so if I run across a decent receiver at a good price, I know if I'd be able to actually use it in my system. Also, any recommendations on a receiver? Want it to be as "future-proof" as possible.. at least 3 HDMI inputs, capable of at least a true 7.1 surround system in the future (not the 'false' 7.1 my current HTIB is), reliable, and any other important things to look for in a receiver these days... Also needs to be at least partly piano black finish. Thanks
CMonMan is offline
post #2 of 4 Old 01-02-2013, 04:24 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Many HTIBs use 4 ohm speakers, which should not be re-purposed for use with an 8 ohm receiver. Check the manual for your HTIB to see what kind of speakers it has. Also, most HTIBs have passive subs connected with speaker wire while most modern receivers use powered subs using a single coax connection.
BIslander is offline
post #3 of 4 Old 01-02-2013, 05:24 PM - Thread Starter
CMonMan's Avatar
Liked: 34
Here is a link to the manual:
http://downloadcenter.samsung.com/content/UM/201202/20120202154053712/HT-D6730W_XAA_web_1226.pdf
It actually appears these speakers have 3Ω impedance!? Is that just the rating that Samsung calls 4Ω? The sub indeed is passive radiator..
Regardless, it appears my initial plan is a no go?
Possibly a better alternative would be to run HDMI cable out of the new receiver (when I get that) to this HTIB receiver, and basically use both until I am able to upgrade the speakers to ones that are compatible with new receiver? I suppose that would defeat the purpose.. Grr. Thanks for the info
CMonMan is offline
post #4 of 4 Old 01-02-2013, 05:33 PM
jdsmoothie's Avatar
Quoted: 12107 Post(s)
Liked: 5511
The 3-ohm speakers would actually be even harder to drive than 4-ohm speakers. If you want to upgrade, sell the HTIB in its entirety and purchase a separate AVR and 7.1 speaker setup.
jdsmoothie is online now
