Pioneer SC-37 shutting off problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-03-2013, 01:23 PM - Thread Starter
blacklab1's Avatar
I've lived with this problem far too long..... when turning on my Panasonic TC-P60ST30 plasma, my receiver, the Pioneer Elite SC-37 turns on with it, but before the tv screen gets running, the receiver shuts off again. Then, I have to turn the receiver on separately and everything works fine. I think a signal from the tv is shutting off my receiver but I don't know how to fix this problem. I would be very grateful if someone could help me. Also, if I have my receiver turned on first, then I try to turn my tv on, the receiver shuts off.
blacklab1 is offline
post #2 of 3 Old 01-03-2013, 04:22 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
Turn off HDMI Control in the receiver...see if that helps. HDMI Control (HDMI CEC) ties the 2 together, so that one can be controlled by the other. You are probably getting spurious behavior from this feature. so don't use it. You'll find it in the Pioneer's HDMI setup menu.
Steve
ss9001 is online now
post #3 of 3 Old 01-04-2013, 08:33 AM - Thread Starter
blacklab1's Avatar
Thanks for the suggestion - it worked. Problem solved.
