"The Official Yamaha RX-V773 Thread" - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #541 of 994 Old 01-15-2014, 10:29 AM
sbmk's Avatar
I can get it for 395€, so it's a real bargain if it can do the job. But if I choose that way, I won't add anything else like another power amp.
The other way I'm exploring is a BDP with FLAC support, high-grade analog audio output or digital with affordable DAC. But it doesn't seem to be many devices available these  days. It's interesting, as I could also play my encoded movies from the same hdd.
But maybe I'm just hoping ...
sbmk is offline
post #542 of 994 Old 01-15-2014, 10:50 AM
usery's Avatar
yes that's a super bargain. in this role the RX-V773 serves solely as network-able music player, DAC built-in. As a bonus you get online radio streaming (Pandora, Sirius, whatever) - but it gotta be connected to a network.
The other way I'm exploring is a BDP with FLAC support, high-grade analog audio output or digital with affordable DAC. But it doesn't seem to be many devices available these  days. It's interesting, as I could also play my encoded movies from the same hdd.  But maybe I'm just hoping ...
are you finding options for this at same price point as above? i didn't - in part that's why i went with the RX-V773.
usery is offline
post #543 of 994 Old 01-15-2014, 10:55 AM
Bond 007's Avatar
Quoted: 2487 Post(s)
Liked: 1968
Thats a good deal but keep in mind its €395 not $395. Im just guessing at around $500.
Licence to Kill
Bond 007 is offline
post #544 of 994 Old 01-15-2014, 10:58 AM
usery's Avatar
from their post it sounds like 395€ is a super bargain for that resident of the EU .
usery is offline
post #545 of 994 Old 01-15-2014, 12:52 PM
sbmk's Avatar
No, I've only found discontinued BDP from Panasonic, streaming devices from Logitech, ... nothing neither current nor affordable. And I don't want to use an HTPC for this.
sbmk is offline
post #546 of 994 Old 01-16-2014, 06:48 AM
usery's Avatar
The Oppo BDP's would do the job - but the more current models are less affordable. The less current model BDP-93 would still do most/all you describe, unknown if available at a bargain in the EU.
usery is offline
post #547 of 994 Old 01-16-2014, 10:24 AM
steveeboy's Avatar
I am not sure if your Crown is different from other power amps or what, but please be advised that I have a vintage Sansui B2101 200w power amp hooked up to my Yamaha RX773 and it works perfectly using the pre-amp capabilities of the Yamaha.
I am running my two main speakers (Cerwin-Vega PD-9s) with the Sansui as power and Yamaha as pre and I do not notice any degradation in sound quality.
I turned it up as loud as I dared (still had plenty of room left) at like 20w/channel and it sounded no different than running my Kenwood Basic C2 as the pre-amp.
I also hooked up a vintage Realistic Receiver to the zone 2 pre-amp outputs of the Yamaha RX773 and that receiver works as an external amplifier as well (using its own volume controls.)
So, I think I would go ahead and try that hook up and see what you think.
I don't think there is any degradation or other issues with using the pre-amp section of the Yamaha to run an external power amp.
sjavs likes this.
steveeboy is offline
post #548 of 994 Old 01-16-2014, 11:00 AM
sjavs's Avatar
Thanks for responding to my post and good to know that the 773 works fine with power amps. To make sure, I will test the pre-amp out on the 773WA with a multi-meter and report the voltage.
sjavs is offline
post #549 of 994 Old 01-16-2014, 11:02 AM
kriktsemaj99's Avatar
Quoted: 647 Post(s)
Liked: 366
...I am running my two main speakers (Cerwin-Vega PD-9s) with the Sansui as power and Yamaha as pre and I do not notice any degradation in sound quality...
According to the specs your Sansui has an input sensitivity of 1V (which matches the nominal 1V output of the 773), while the Crown XLS is 1.4V. So it's possible the 773 can't drive the Crown to its full-rated power, but in practice I don't know if that's really an issue.
kriktsemaj99 is offline
post #550 of 994 Old 01-16-2014, 11:04 AM
sjavs's Avatar
Originally Posted by kriktsemaj99 View Post
According to the specs your Sansui has an input sensitivity of 1V (which matches the nominal 1V output of the 773), while the Crown XLS is 1.4V. So it's possible 773 can't drive the Crown to its full-rated power, but in practice I don't know if that's really an issue.
Where did you get the 1V output spec of the 773?
sjavs is offline
post #551 of 994 Old 01-16-2014, 11:08 AM
Bond 007's Avatar
Liked: 1968
Probably in the Owners manual.
Licence to Kill
Bond 007 is offline
post #552 of 994 Old 01-16-2014, 11:10 AM
Quoted: 647 Post(s)
Liked: 366
All recent Yamahas have 1.0V pre-outs according to the manuals. For some reason they forgot to put this in the 773 manual, probably because it's a combined 673/773 manual and the 673 has no pre-outs. But it would useful if somebody reports actual voltage measurements.
post #553 of 994 Old 01-16-2014, 11:21 AM
ThinkRationally's Avatar
Quoted: 44 Post(s)
Liked: 79
I think this is noted in the specification pages near the end of the manual. I'm pretty sure I found it there, because I was looking for the sub out level recently.
ThinkRationally is offline
post #554 of 994 Old 01-16-2014, 11:36 AM
Quoted: 44 Post(s)
Liked: 79
Hmm, this is what it says on page 130 of the manual:
Output level/Output Impedance
REC OUT......................200 mV/1.2 kOhms
SUBWOOFER................1 V/1.2 kOhms
ZONE2 OUT..................200 mV/1.2 kOhms
So are all the pre-outs 200mV? The AV inputs are spec'ed at 200mV, so it would make sense that inputs and outputs are the same.
EDIT: It lists the MAX input signal on the AV inputs as 2.3 V.
post #555 of 994 Old 01-16-2014, 11:40 AM
Quoted: 647 Post(s)
Liked: 366
The pre-outs are 1.0V and the manual should list them separately (as the other manuals do, e.g. the 775 manual), but they forgot for the 773 and only included the SUB pre-out voltage (which used to be different on older models, but is now the same 1.0V as the main channels).
post #556 of 994 Old 01-16-2014, 11:45 AM
Quoted: 44 Post(s)
Liked: 79
The pre-outs are 1.0V and the manual should list them separately (as the other manuals do, e.g. the 1073 manual), but they forgot for the 773 and only included the SUB pre-out voltage (which used to be different on older models, but it now the same 1.0V as the main channels).
It is odd that the output section doesn't list the 673 and 773 separately. It does list the Zone 2 outputs, though, as 200 mV. Zone 2 would apply to both units. Would the non-zone 2 outputs be different than the zone 2 outputs? Is the manual incorrect? Or maybe I'm looking at the wrong spec.
post #557 of 994 Old 01-16-2014, 11:50 AM
Quoted: 647 Post(s)
Liked: 366
I think they messed up that section of the specs pretty badly, because I'm pretty sure the zone2 out should be 1.0V as well (it's always been that way, and zone outs are still listed as 1.0V for the A1020, 1030 etc.). The AV (REC) out is different, and I think 200mV is correct for that.
post #558 of 994 Old 01-16-2014, 11:51 AM
Quoted: 44 Post(s)
Liked: 79
It wouldn't surprise me.
post #559 of 994 Old 01-16-2014, 11:53 AM
sjavs's Avatar
I think they messed up that section of the specs pretty badly, because I'm pretty sure the zone2 out should be 1.0V as well (it's always been that way, and zone outs are still listed as 1.0V for the A1020, 1030 etc.). The REC out is different, and I think 200mV is correct for that.
I think the only good way is to test with a multi meter. Too bad, I don't have a 773WA at work :P
sjavs is offline
post #560 of 994 Old 01-16-2014, 11:58 AM
Quoted: 647 Post(s)
Liked: 366
If you measure it you'll probably find the peak voltage is considerably more than 1V anyway (if cranking the master volume while playing a suitable test tone). They don't define what they mean by 1.0V, but I don't think it's the max voltage you can get from the pre-outs.
post #561 of 994 Old 01-16-2014, 12:04 PM
Quoted: 44 Post(s)
Liked: 79
I assumed it was peak RMS, but now I'm darn curious. If someone measures this, please share your findings. If you don't mind, I'd be interested in the sub out measurement as well. I'm looking at a miniDSP to EQ my sub, and I want to have the right input sensitivity on the mini so I have headroom and don't overdrive its inputs.
EDIT: "Peak RMS" may sound like two different specs--I meant the highest expected RMS value.
post #562 of 994 Old 01-16-2014, 12:31 PM
kenroj's Avatar
just join the RX-V773 club from Newegg for 449.00. I couldn't resist.
Mattyo1612 likes this.
kenroj is offline
post #563 of 994 Old 01-16-2014, 12:36 PM
Bond 007's Avatar
Liked: 1968
Thats a good deal. Congrats.
Licence to Kill
Bond 007 is offline
post #564 of 994 Old 01-16-2014, 02:26 PM
sjavs's Avatar
sjavs is offline
post #565 of 994 Old 01-16-2014, 02:46 PM
kenroj's Avatar
I was happy with the price also got 25 off for and issue I had with them.
kenroj is offline
post #566 of 994 Old 01-16-2014, 05:36 PM
papashango61's Avatar
just got this, great so far. easily powers the B&W pm1s and sounds great. any easy way to turn on/off the initial YPAO settings?
papashango61 is offline
post #567 of 994 Old 01-16-2014, 05:44 PM
Quoted: 44 Post(s)
Liked: 79
Good to hear. You can bypass the YPAO settings at any time by selecting the Through option in the manual setup. By initial, do you mean you ran YPAO once already? If not, I'm not sure that the AVR comes with a default YPAO curve that differs from Through (which applies no PEQ curve, so the same as Through). If it does, it surely won't be match for your room anyway.
post #568 of 994 Old 01-16-2014, 08:23 PM
i ran it once, and my initial casual judgement is that it did not help things..wish there was just an "on/off" button to compare them.
post #569 of 994 Old 01-16-2014, 08:52 PM
Bond 007's Avatar
Liked: 1968
There is. Its called Through. Thats what ThinkRationally was trying to tell you.
Licence to Kill
Bond 007 is offline
post #570 of 994 Old 01-16-2014, 09:18 PM
my impression from his post is i have to go through setup menus on the tv screen, where i was hoping for just a button on the remote
Yamaha Rx V773wa Receiver
