"The Official Yamaha RX-V773 Thread" - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #901 of 994 Old 05-27-2014, 06:48 PM
Bond 007's Avatar
Quoted: 2434 Post(s)
Liked: 1950
Originally Posted by Pablo Albino View Post
Hi guys! I`m wondering about upgrade my Marantz SR5005 and the RX773 is in sight!
Is there a way to set the crossover to different values for rear and front speakers? I could do that on my 5005...
No. 773 has a global crossover for all speakers.
Licence to Kill
Bond 007 is online now
post #902 of 994 Old 05-28-2014, 04:12 PM
Pablo Albino's Avatar
It`s a shame... :/
Thank you!
Pablo Albino is offline
post #903 of 994 Old 06-03-2014, 03:01 AM
Bond 007's Avatar
Liked: 1950
post #904 of 994 Old 06-10-2014, 05:12 PM
TKE577's Avatar
First, thank you to the community there is a treasure trove of information here that I have benefited from over the years.
I've done some searching and haven't found a solution to this yet.  Hoping someone here can help.
I have the receiver setup now and it's working fine except for one issue.
I have my living room TV and my bedroom TV hooked up to the HDMI 1 and 2 OUT on the receiver.
If I have the receiver in pass through mode ( and shut it down) both video and audio pass through to both TV's fine.  If I fire up the receiver I only get sound in the living room area (5.1 setup) and video works in both the living room and bedroom.  I'd like to have sound in both but I have yet to be able to do this.
Now I'm fine with shutting down the receiver to get sound in the bedroom TV if that is how it has to be.  I was curious though if there was a setting or something which is preventing the sound from going to both TV's at the same time?
Thank you in advance for the help.
TKE577 is offline
post #905 of 994 Old 06-10-2014, 05:36 PM
TKE577's Avatar
So I post this and then find a fix.  Go figure.
Anyway if anyone is curious the fix was under onscreen>setuphadmi>hdmi control >
Set that to off
Then under audtio output change HDMI 1 and 2 to on.
Now I messed with this previously.  I never turned off HDMI control but did set HDMI 2 to on which did NOT work.  Go figure I ask the question and find the answer 5 minutes later despite messing with settings for an hour plus prior to asking.
Anyway, problem solved.
TKE577 is offline
post #906 of 994 Old 06-10-2014, 06:00 PM
Bond 007's Avatar
Liked: 1950
Set that to off
HDMI Control by definition turns things on and off. Many times its more of an inconvenience than a convenience. You shouldnt have any more problems.
Licence to Kill
post #907 of 994 Old 07-14-2014, 10:01 AM
mv213's Avatar
Question for guys using hard-wired ethernet RX-V773
I'm running mine (bought in 2012) with the included wi-fi adapter. When listening to internet radio, often the stream will stop and I have to either manually choose the stream again with the remote app; or sometimes it will start again by itself; or sometimes it will switch to a completely different stream in my bookmarks.
I'm wondering if I went to hard-wired ethernet if this issue will go away. Anybody running hard wired and listening to net radio able to answer this>?
Thanks so much,
jpm
mv213 is offline
post #908 of 994 Old 07-14-2014, 10:34 AM
stereo55's Avatar
Thanks so much,
jpm
Running a RX-A820 (basicly the same as a 773) hardwired (FIOS) and have no problems with net radio .
I miss my old Altec 1590 monoblocks ....
stereo55 is offline
post #909 of 994 Old 07-14-2014, 11:01 AM
mv213's Avatar
Thanks, I was hoping that was it. I've heard lots of complaints about the Yamaha wi-fi adapter. My Roku 3 sitting right next to it pretty much never loses connection. We are getting ready to move so in the new place I'll have an ethernet cable run to the stereo location.
mv213 is offline
post #910 of 994 Old 07-27-2014, 01:45 PM
Cla55clown's Avatar
Quoted: 138 Post(s)
Liked: 71
Don't get me started on the Yamaha wifi adapter. I wish I could get that $80 back! Piece of garbage I have to manually reboot the thing on average twice for a one hour show. None of my other wifi devices in the house have issues.
Cla55clown is offline
post #911 of 994 Old 09-09-2014, 04:58 PM
Liked: 0
Does anybody have an idea how to watch TV and have the audio from another source, for example through airplay of the iphone, without messing with the cables on the back of the amp.
Basicly i want to watch TV (which is an HDMi Zone 1 source) together with my own audio through airplay. Don't know if it is possible to combine this.
Tried it with the zone features of the 773, zone 2 is not helping me out solving this so far.
michelos is offline
post #912 of 994 Old 09-09-2014, 06:01 PM
kriktsemaj99's Avatar
Quoted: 645 Post(s)
Liked: 364
You can do it by setting "Video Out" for your audio source using the Input menu (page 83 of the 773 manual).
kriktsemaj99 is offline
post #913 of 994 Old 09-10-2014, 10:02 AM
Liked: 0
Thanks alot man. Worked out. So glad I can watch football now without terrible commentators, and with custom music tracks.
michelos is offline
post #914 of 994 Old 10-05-2014, 08:50 PM
Liked: 0
If you can assign a static IP for it that may fixa lot of the problems. I've noticed not just with this, but with a lot of WIFI accessories, printers, etc. . . (basically a ton of things that aren't computers or smartphones), that assigning a static IP usually fixes most connection issues. Instead of assigning a new one every time it connects, it always has a dedicated IP address with no conflicts or DHCP issues.
DHCP can be a real help for quick connections or a pain in the rear. For devices that are always on or always connected, taking the time to set up a static IP in your wireless router is worth it.
DoomsdayJesus is offline
post #915 of 994 Old 10-05-2014, 08:57 PM
Liked: 0
Thanks so much,
jpm
I ran hard wired until I ran out of ethernet ports on my router. I honestly had no difference between the two. I'm essentially IT where I work though, so I'm pretty thorough with my router configs. My YWA-10 is also about four feet from my router, so that helps, too. The only issue I've had is with the app freezing or dropping streaming music while I'm working in the garage where I have some remote speakers, but I think that has more to do with the app stability than the wifi connection. Especially since the app goes through the router before it goes to the YWA-10.
If anyone has questions about router or wifi configs, feel free to PM me. It may take me a bit to get back to you, but I will.
post #916 of 994 Old 10-19-2014, 09:38 AM
cesar123's Avatar
Quoted: 373 Post(s)
Liked: 548
Amazon has the A830 for $450.
Deal ends at midnight.
cesar123 is offline
post #917 of 994 Old 10-19-2014, 09:42 AM
Biggzy32's Avatar
Quoted: 25 Post(s)
I don't really know much about receivers. Is it a good one? Is it a good deal?
I'm looking into getting the Vizio P series TV and would need to get an AVR.
Biggzy32 is offline
post #918 of 994 Old 10-19-2014, 09:47 AM
cesar123's Avatar
Quoted: 373 Post(s)
Liked: 548
I'm biased because I am a Yamaha fan. I have the 773 and am extremely happy with it.
I got mine for 400, so this deal is even better.
cesar123 is offline
post #919 of 994 Old 10-19-2014, 10:18 AM
Bond 007's Avatar
Liked: 1950
Great deal.
post #920 of 994 Old 10-19-2014, 10:54 AM
Biggzy32's Avatar
Quoted: 25 Post(s)
Thanks guys!
Biggzy32 is offline
post #921 of 994 Old 10-19-2014, 02:19 PM
Cla55clown's Avatar
Quoted: 138 Post(s)
Liked: 71
I saw this too and was tempted to get it but I don't feel it offers a huge advantage over my current RX-V673. Are the DACs that much better in the Aventage line to warrant the upgrade? What do you guys think?
post #922 of 994 Old 10-28-2014, 02:42 AM
Tan39's Avatar
Hdmi output only sound no picture
Hi all, sorry if this has been asked before, my yamaha rx-v773 has problems with one hdmi output. I am getting only sound but no picture. The other output works fine, I tested the cables etc, so it's an issue with that output in particular. Any advise before I ring yamaha? Thank you.
Tan39 is offline
post #923 of 994 Old 11-03-2014, 11:18 AM
Liked: 0
Question Bi-amp and subwoofer connection
Hi guys,
My HiFi/AV system is :
- Yamaha RX-V773 AV receiver
- Monitor Audio Silver 6 floor speakers (Fronts)
- Mirage Nanosat Prestige surround speaker (rears)
- Mirage Nano CC centre speaker
- NO subwoofer jet.
I'am interested in a REL subwoofer, model Quake or Q100E, and to connect the two front speakers bi-amp to the receiver.
The REL Subwoofer has a LFE input phono socket to connect the Sub Base System to the LFE/Sub output to the receiver (sub 1 or 2?). It also has a HI LEVEL input Neutrik Speakon socket to connect the Sub Base System to the main front speaker terminals of the receiver.
Questions:
What is the advantage to connect the Monitor Audio speakers bi-amp? More volume?
What is the best connection for the Sub Base System (stereo / movie)?
When using bi-amp optie, can I still using the Neutrik Speakon to connect the Sub Base System to the front speakers terminals of the receiver?
When playing in stereo is sub 1 and /or 2 active? Is the output low frequency incl. LFE?
Mercedes01 is offline
post #924 of 994 Old 11-03-2014, 11:34 AM
ThinkRationally's Avatar
Quoted: 44 Post(s)
Liked: 79
Originally Posted by Mercedes01 View Post
Hi guys,
Questions:
Many would say there is no advantage, and not to bother. I can't really answer this from experience, though.
Sub 1 and Sub 2 always have the same signal, as far as I know. There is only a single, mono sub output from the AVR. Sub 1 and 2 are essentially just split inside the chassis. It will include LFE if there is an LFE track in the source material. If not, it will still include frequencies below the sub crossover setting. If you're running your speakers as large, and using extra bass, then you'll get a duplication of bass frequencies across your speakers and sub.
Your other questions seemed to be about speaker level inputs on the sub (I may be wrong here). Since the AVR does bass management, it's not required that you use these (much simpler not to, at least). You can just use the LFE input.
Others may correct me if I'm wrong here.
ThinkRationally is offline
post #925 of 994 Old 11-03-2014, 12:52 PM
Liked: 0
Exclamation Neutrik Speakon
Info neutrik speakon REL subwoofer connection :
rel.net/support/rel-connectivity/
post #926 of 994 Old 11-03-2014, 01:07 PM
Quoted: 44 Post(s)
Liked: 79
You can use just the LFE connection. I have no experience using both speaker level and LFE connections. One reason to suggest against this is if your AVR is the only amp you have driving your speakers, you will take a load off if it by running your speakers as small instead of large and setting a sub crossover in the AVR. If you want two subs with stereo bass, you'll have to use the speaker level inputs, though.
Remember that if you run the speakers as small, the sub will get the LFE channel plus any frequencies below the crossover that would have otherwise gone to the speakers, so you won't be missing any sound just using the LFE from one of the sub outputs.
Someone with experience running both types of inputs could get you further than I can on that topic. You might find something the sub forum.
post #927 of 994 Old 11-17-2014, 02:54 AM - Thread Starter
Mattyo1612's Avatar
Quoted: 25 Post(s)
Liked: 41
Firmware update 1.85 available on the Australian Yamaha site
Mattyo1612 is offline
post #928 of 994 Old 11-17-2014, 02:57 AM - Thread Starter
Mattyo1612's Avatar
Quoted: 25 Post(s)
Liked: 41
Firmware update 1.85 available on Australian Yamaha site.
post #929 of 994 Old 11-17-2014, 05:59 AM
Cla55clown's Avatar
Quoted: 138 Post(s)
Liked: 71
What does the update supposedly fix?
post #930 of 994 Old 11-17-2014, 10:26 AM
stereo55's Avatar
Firmware update 1.85 also available for the RX-A820 (USA) .
Not sure what it updated , but all went well the the update .
May be my imagination , but some of my bluray movies sound a tad better now and maybe even some of the Amazon VOD's in 5.1 .
stereo55 is offline
Yamaha Rx V773wa Receiver
