"The Official Yamaha RX-V773 Thread" - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #991 of 1001 Old 08-04-2016, 03:36 AM - Thread Starter
Mattyo1612's Avatar
Quoted: 26 Post(s)
Liked: 42
New firmware update 1.96 now available on Yamaha's Australian website
halflifecrysis likes this.
Mattyo1612 is offline
post #992 of 1001 Old 10-22-2016, 03:50 AM
basss's Avatar
Will this receiver be able to properly pass thru PS4 PRO 4k/hdr?
And also use 4k with the new Chromecast Ultra?
I saw something about HDMI 2.0 or 2.0a being necessary? And this receiver only has HDMI 1.4a?
basss is offline
post #993 of 1001 Old 01-04-2017, 05:45 PM - Thread Starter
Mattyo1612's Avatar
Quoted: 26 Post(s)
Liked: 42
Has anyone tried the YBA-11 Bluetooth adapter with this receiver? I have the YWA-10 Wi-Fi adapter which works fine but I'm curious to know if the Bluetooth adapter is worthwhile?
post #994 of 1001 Old 04-02-2017, 07:10 AM
Liked: 0
What did you find out?
halflifecrysis is offline
post #995 of 1001 Old 05-25-2017, 06:55 AM
gadrago's Avatar
On firmware 1.98 since April 4, 2017. Pandora was working initially on my RX-V773 on this firmware release but quit working in recent weeks with the 'Access Error' and 'No network found' messages, even though vTuner continued to work. My receiver was already on a static IP address from the router end. As suggested elsewhere, I got Pandora access restored by going into the receiver Setup, Network, IP address section and disabling DHCP. I then manually entered the receiver's static IP address, the router's subnet mask and gateway address, and changed the primary and secondary DNS servers from '0.0.0.0' to the Google '8.8.8.8' and '8.8.4.4', respectively. Pandora access was immediately restored.
gadrago is offline
post #996 of 1001 Old 06-12-2017, 01:56 AM
Liked: 0
no output from yamaha rxv 773
Hi Ii have a Yamaha rxv-773 that has no output since a power outage last week. It powers up and the front display is working and showing the unit is responding to the remote . But there is no output from hdmi 1 or 2. I have performed a reset and tried a different tv but no output. Do these have any internal fuses that can be checked before i try to get it repaired by yamaha ?
alibongo is offline
post #997 of 1001 Old 06-12-2017, 05:08 AM
jdsmoothie's Avatar
Quoted: 14628 Post(s)
Liked: 6962
This model is well out of it's 2 year warranty period so your best bet is to just open it up and check for anything unusual that you might be able to replace, otherwise, consider one of the newer models that have Atmos/DTS:X/4k pass through capability rather than going the repair route on your own dime.
jdsmoothie is offline
post #998 of 1001 Old 06-12-2017, 12:31 PM
ChromeJob's Avatar
Quoted: 1170 Post(s)
Liked: 604
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
Newer models like my 775 may also offer more advanced network streaming options, and support for teh AV Controller app (don't know if the 773 is covered by the app).
I would recommend nothing older than a RX-v779 for proper 4K UHD support that will last a few years (HDMI out supports HDCP 2.2, 60Hz UHD). Currently there are deals to be found on the '81 series, e.g. RX-v781/TSR-7810, RX-v581/TSR-5810,…
“Phil? Phil Connors?!”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is offline
post #999 of 1001 Old 06-25-2017, 05:59 PM
Goughy's Avatar
Hey all! I'm pretty late to the party, having only gotten my hands on a 773 yesterday. I have a little question, but don't know if anyone will have an answer.
It's connect to my LG smart TV via hdmi arc. But it seems when ever the channel from the TV is dolby digital (some channels and netflix) the screen on the front of my 773 keeps changing from saying 'Dolby Digital' to 'PL II Movie', and then back again and so on and so on, every few seconds. For TV signals that aren't in Digital, it just stays on 'PL II Movie'.
When it's connected to my Media Center pc, it just stays on what ever the source material is. So if it's the netflix app on my pc, or from mediaportal and is Digital it just stays on 'Dolby Digital', no flicking back and forth. Same with dvd's and blurays.
So I'm just wondering if anyone has a clue why the display keeps continually changing? I don't notice it too much, but it'll drive my wife nuts!
Thanks heaps.
Goughy is offline
post #1000 of 1001 Old 06-26-2017, 06:38 AM
ChromeJob's Avatar
Liked: 604
Dolby Digital can be streamed as 2.0 as well as 5.1. Sounds like the AVR is set to SUR DECODE and is showing you the codec as well as the decoder in use. If the 773 has on screen information, enable that to determine what the TV is providing for an audio stream.
post #1001 of 1001 Old 06-26-2017, 02:38 PM
Goughy's Avatar
Wel....... don't I feel like a doofus!! Thanks for that. Just had to scroll through the info button and set it to input instead of Surround Decode. And yes, when I press the Straight button the signal changed to just stereo with only the L and R speakers indicated on the amp. Thanks for that
ChromeJob likes this.
Goughy is offline
Yamaha Rx V773wa Receiver
