Anyone here using an Emotiva UMC-200? What are your thoughts? - Page 18 - AVS Forum
 2Likes
post #511 of 539 Old 02-02-2014, 08:34 AM
nvidio's Avatar
Quoted: 78 Post(s)
Liked: 25
Originally Posted by chalugadp View Post
Time to get some of these with 98 db sensativity
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion12-kit.html
I have gone to waveguides with high sensativity and will never go back smile.gif
Dream on.
nvidio is offline
post #512 of 539 Old 02-02-2014, 09:07 AM
PGT FTW's Avatar
Liked: 25
dream on?
PGT FTW is offline
post #513 of 539 Old 02-03-2014, 02:23 AM
nvidio's Avatar
Quoted: 78 Post(s)
Liked: 25
Originally Posted by PGT FTW View Post
dream on?
nvidio is offline
post #514 of 539 Old 02-03-2014, 05:10 AM
PGT FTW's Avatar
Liked: 25
About what?
PGT FTW is offline
post #515 of 539 Old 02-03-2014, 12:11 PM
nvidio's Avatar
Quoted: 78 Post(s)
Liked: 25
About what?
About the "time to get these speakers" remark, obviously. To put it mildly, my Canton Vento 890.2 DCs blow them away all day long and twice on Sunday.
nvidio is offline
post #516 of 539 Old 02-03-2014, 12:16 PM
Quoted: 96 Post(s)
Liked: 75
About what?
In what regard? Have you owned both? The canton may sound good but based on specs it doesn't appear they will play nearly as loud as the fusion speakers.
dwaleke is online now
post #517 of 539 Old 02-03-2014, 12:51 PM
PGT FTW's Avatar
Liked: 25
So, $6k speakers are better than $500 speakers? Get the **** out!
thrillcat likes this.
PGT FTW is offline
post #518 of 539 Old 02-03-2014, 01:37 PM
chalugadp's Avatar
Quoted: 1381 Post(s)
Liked: 1227
About what?
If you use them for music then yes I am sure they will beat my seos speakers. For movies nope. Your little tweeter on those will not be able to handle 110 dbs without compressing the sound. The soundstage will also not be as wide since your not using directional based speakers . I don't care if you spent 20 grand. The parts on those Canton speakers are only worth around 1-1.5 k. There designed for music.
chalugadp is online now
post #519 of 539 Old 02-03-2014, 02:44 PM
neo_2009's Avatar
Quoted: 17 Post(s)
.. as close to the rew settings as you can get.
REW version b18 will generate the PEQ filters for the UMC-200.
See : http://www.hometheatershack.com/forums/rew-forum/47461-v5-10-beta-release-asio-support-43.html#post668288
neo_2009 is online now
post #520 of 539 Old 02-03-2014, 06:00 PM
chalugadp's Avatar
Liked: 1227
Your right. :thumbup:
post #521 of 539 Old 02-03-2014, 06:30 PM
freespace303's Avatar
Liked: 95
Originally Posted by 316 View Post
Wow am I glad I saw this post. It seems you had the luxury of having your speakers already in place and used to them before adding the Emo combo, I was using my speakers and umc 200 for the first time together and man did the emoq throw me for a loop! Sucked the mids & lows out is an understatement!
For music it is the most terrible experience I have ever had, but the strange thing is for movies it works great, What I did was let the emoq do its thing for movies, and when I listen to music I set emoq to flat and run my outboard EQ's and my music is great. I bypass my outboard eq's when watching movies, in fact I turn the Eq's off.
Yup, here are some of my updated replies though. (cliff notes is that I found a setting a liked, after running a few times, setting the mic on the recliner and me not being in the room during the test)
post #482
post #492
post #496
Also, it's good to see this thread have some activity! The UMC-200 is the one part in my system where I know it could sound better if I do more research and try more settings. And this forum/thread is where I do most of my research, lol.
AVR - Emotiva UMC-200 + UPA-700 / Sources - PS3/Xbox360
Fronts - Klipsch KF-28 / Center - Klipsch RC-62
Sides - Klipsch VS-14 / Rears - Klipsch VS-14
Sub1 - SVS PB12-NSD / Sub2 - SVS PB12-NSD
PRJ - Mitsubishi HC5 / SCN - 120" ES cinewhite
freespace303 is offline
post #522 of 539 Old 02-03-2014, 10:21 PM
chalugadp's Avatar
Liked: 1227
^^^ try this setting
Go to one of the three manual settings and try this for your mains ,
82 hz +3
95 hz +2.5
125hz + 2.5
300hz - 1.5
450hz -1
800hz +1
1.7k +2
3k +2
5k +2.5
Yes its a typical house curve. Q between 6-12. Switch from your setting to this and see if you like it. I use my inuke3000 dsp to eq my sub. It does a much better job then emo with its 7 bands .
post #523 of 539 Old 02-04-2014, 12:01 AM
316
316's Avatar
Liked: 25
post #482
post #492
post #496
Thanks for the update.....I still find with my 31 band eq's I have more control and will be able to dial it in much better once everything is setup permanently in the HT.
Have a Happy and safe New Year!!!
316 is offline
post #524 of 539 Old 02-04-2014, 12:30 AM
chalugadp's Avatar
Liked: 1227
post #525 of 539 Old 02-04-2014, 05:24 AM
316
316's Avatar
Liked: 25
I had the wife yell at me once...she was trying to sleep on the other side of the house, I told her it was urapnes & LTD02's fault biggrin.gif
316 is offline
post #526 of 539 Old 02-08-2014, 04:42 PM
nvidio's Avatar
Quoted: 78 Post(s)
Liked: 25
nvidio is offline
post #527 of 539 Old 02-08-2014, 05:21 PM
chalugadp's Avatar
Liked: 1227
I used to be like you with b&w speakers . Then I saw the light with pro audio style. I also have better woodworking skills then the dudes making the cantons. Why pay 4-5 k in markup when you don't have to. I love customizing with the peq of the umc200
post #528 of 539 Old 02-09-2014, 06:11 AM
nvidio's Avatar
Quoted: 78 Post(s)
Liked: 25
There is quite a big difference between Bowers & Wilkins and Canton.
Although I agree a lot of "boutique" gear happens to be terribly overpriced for the performance you get, there are a few exceptions nevertheless, and all pro gear is not necessarily all that special either. This might help to explain why my system contains both pro gear AND high quality Hi-Fi gear.
Even if you did, it wouldn't make a whole lot of difference anyway because the speaker cabinets of my Canton Vento 890.2 DCs are aluminum. wink.gif
Nobody has to do anything, it's a free world. I always love it when people blow smoke on the internet, it makes for solid entertainment.. biggrin.gif
And don't we all? I mean, I already mentioned earlier in the thread the fact I also own an UMC-200, so what exactly is your point?
nvidio is offline
post #529 of 539 Old 02-11-2014, 07:42 PM
Frank D's Avatar
Quoted: 36 Post(s)
Liked: 27
Originally Posted by Bill Mac View Post
I would like to see Emotiva succeed as well. But for me the UMC-200 and UMC-500 do not offer the features that I'm looking for. The XMC-1 has my interest but only if TacT is as good if not better than XT32. The ongoing delay of the XMC-1s release has me thinking that implementing TacT in a $1500 prepro is more challenging than originally thought.
Bill
Are they using TACT? I thought they where using DIRAC or is TACT and DIRAC the same thing?
Frank D is offline
post #530 of 539 Old 02-11-2014, 08:11 PM
nvidio's Avatar
Quoted: 78 Post(s)
Liked: 25
They were kind of forced away from TacT because it was technically impossible to fit into the XMC-1 without making major modifications so they finally decided to go for Dirac Live instead. The official word from Big Dan is it will be made in USA and it will ship with HDMI 2.0 instead of HDMI 1.4.
[UPDATE] -- A word about HDMI 2.0 and the XMC-1...
nvidio is offline
post #531 of 539 Old 09-24-2014, 06:40 PM
cbaseuser's Avatar
Quoted: 12 Post(s)
quick question....
I don't plan on using the on screen display initially...
Can all the parameters be accessed through the units own display, as far as setup, speaker levels, distance, crossover, etc.?
thanks
cbaseuser is offline
post #532 of 539 Old 09-24-2014, 07:58 PM
oatmeal769's Avatar
Yes, but have the manual nearby to decipher. Otherwise it'll be a PITA.
oatmeal769 is offline
post #533 of 539 Old 09-25-2014, 02:57 AM
neo_2009's Avatar
Quoted: 17 Post(s)
Originally Posted by oatmeal769 View Post
Yes, but have the manual nearby to decipher ...
Instead of using the UMC-200 manual, use the Fusion 8100 instead, it's much more complete.
The platform is exactly the same: https://emotiva.com/resources/manual...manual_v10.pdf
oatmeal769 likes this.
post #534 of 539 Old 09-25-2014, 10:58 AM
cbaseuser's Avatar
Quoted: 12 Post(s)
thanks for the 8100 manual tip!
post #535 of 539 Old 10-17-2014, 11:33 AM
mstang1988's Avatar
I'm considering the migration from a Rotel RSP-1068 to the UMC-200. How does this sound for 2ch music comparatively? Is there adjustments for levels given different input types (DTS vs Dolby vs PCM)? I've read a few reviews and it sounds like a great little box with a few HDMI handshaking issues.
Has anybody made a similar migration that favors 2ch quality over 5.1 or 7.1 quality?
I will be using with:
Rotel RB-1091 Monoblocks (Mains)
Rotel RMB-1085 (Center/Surrounds)
RTi12 mains
CSi5 Center
RTi5 Surrounds or possibly Ansonica's (Building them now)
mstang1988 is offline
post #536 of 539 Old 10-17-2014, 12:15 PM
markus767's Avatar
Quoted: 1207 Post(s)
Liked: 470
No.
More UMC-200 information: "Official" Emotiva UMC-200 Thread
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is online now
post #537 of 539 Old 10-17-2014, 05:10 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 158
Originally Posted by markus767 View Post
No.
I'm pretty sure that it does Markus. If you look in the playback sub menu(I think) it shows levels for each of the formats that you can adjust. I don't have it right in front of me but I'm sure I've seen that screen.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #538 of 539 Old 10-18-2014, 01:30 AM
markus767's Avatar
Liked: 470
No. In Setup > Playback you can define how each input format is processed. No level setting.
Markus
post #539 of 539 Old 10-18-2014, 07:32 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 158
It was the LFE level per CODEC that I was thinking of.
Monoprice 6ft Ultra Slim Series High Speed Hdmi Cable W Redmere Technology Black , Emotiva
