Yamaha Receiver RX-A720 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-04-2013, 10:25 AM - Thread Starter
Meyer23's Avatar
Hi, I'm new here but have been lurking for quite some time. At the end of last year I purchased the Yamaha RX-A720 and love it. Recently my Dad was in town and when I wasn't home, he was playing with the receiver and some how changed a setting and it's driving me crazy. When I boot up the receiver it use to always default to Scene2 TV and the sound would work fine. Now, when I turn on the receiver and the TV, it goes to TV Viewing but then defaults to AUDIO1. After I hit the TV SCENE button again, it will go to TV Viewing, sound will work and then for a 2nd time, go back to AUDIO1. I'm not sure what I'm missing but it's really bugging me that I can't figure out how to get it back to just turn it on without it going to AUDIO1 twice before working properly. Hopefully some can give me a hand, it would be much appreciated. Thank you.
Ed
Meyer23 is offline
post #2 of 9 Old 01-04-2013, 11:02 AM
BobL's Avatar
Liked: 56
Set the input and surround mode you want using either the remote or front panel. Hold down Scene2 TV on the front panel of the receiver for ~5 seconds. Those settings will now be stored under Scene2.
Meyer23 likes this.
BobL is offline
post #3 of 9 Old 01-04-2013, 11:52 AM - Thread Starter
Meyer23's Avatar
Thank you for the reply but unfortunately that didn't work. It still goes to AUDIO1 twice.
I have been playing with this thing for a couple hours now. Is there a way to hard reset the whole system? I am at a stand still. I know it's minor but it's driving me crazy.
Meyer23 is offline
post #4 of 9 Old 01-04-2013, 01:38 PM
BobL's Avatar
Liked: 56
Is audio1 set up as the audio in for that connection ?HDMI. You'd have to change that in the set up menu.
Meyer23 likes this.
BobL is offline
post #5 of 9 Old 01-04-2013, 07:32 PM - Thread Starter
Meyer23's Avatar
I played with the menu quite a bit and couldn't find anything but I'll try and check the menu again when I get home from work and see if I can find a setting within the receiver. I think I understand what you are asking, I'll try and see what I can find again.
Update: My HDMI1: Audio In is checked with HDMI1. Not Audio1.
Meyer23 is offline
post #6 of 9 Old 01-04-2013, 11:08 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Meyer23, possible receiver HDMI Control has been turned on or the tv HDMI Control is turned on.
JChin is offline
post #7 of 9 Old 03-08-2013, 12:39 PM
chirpy's Avatar
I'm having the same problem as the original poster. I have HDMI Control turned on, because when I use Netflix on my SmartTv, I want the audio to play through ARC.
However, the Yamaha always sets the audio input as AV4 when I turn it on, when instead it should be using HDMI2.
Is there a way to use HDMI Control & ARC - and have automatically set it to HDMI2 for input? Or maybe there's a better way to configure this?
chirpy is offline
post #8 of 9 Old 01-25-2014, 02:08 PM - Thread Starter
Meyer23's Avatar
I forgot what I did to fix the problem originally but what what I ended up doing was using an Optical Cable and now it works fine. It defaults to AV4 but that is the correct connection for the Optical cable.
The issue I've had since I got the unit is when watching a program (recorded or live) is the sound constantly glitches or cuts out for a second or two, then goes back to normal. While I thought it was the new X1 box I got from Comcast, they assure me after about 3-4 trips out that my signal is absolutely perfect. What I tried was when the sound cuts out or glitches, I rewind it. What I find is that if it was the box, the glitch/sound cutting out should still be there, correct? Because it would have been recorded. It's not though. If I get a glitch or freeze in audio, rewind it, it's gone. That's what leads me to believe there is some type of connect issue between the X1 box and the Receiver. Just curious if anyone has a suggestion or anything at all that would help. I've been through the CD and the menu with no luck. Thank you.
Meyer23 is offline
post #9 of 9 Old 01-29-2015, 07:18 AM
Liked: 0
Question TV audio through ARC
Hello,
We just got a new tv that supports ARC and I want to take advantage of it. I would like to be able to watch regular TV and have the audio come to the receiver via ARC but I can't get it to work. HDMI control and ARC are turned on in the receiver. The TV is a Vizio M602i-B3 and its digital output is set to Bitstream. I don't think there are any other settings in the TV unless there is an HDMI control setting. I was working on this until late last night so I didn't get that far. Any help would be greatly appreciated!
atoddvr6 is offline
Yamaha Rx A720 7 2 Channel Network Aventage Av Receiver
