Need Receiver Help!!! Height Restriction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-04-2013, 01:48 PM - Thread Starter
PawnPower's Avatar
To keep it brief...I have combed through dozens of av receivers looking for something that will work for my media console
The receiver will be used for an exercise room, TV has only 1 HDMI input and I need to hook up DVD player, Xbox 360, and DISH receiver.
The space I have to work with is 6". I realize there would be a ventilation problem which is why I would use these on top of the receiver over the vents
The blower fans are 22mm high leaving 130mm or 5.1" for the receiver.
Needs
* Under $300 (wife's limit)
* 3 HDMI inputs 1.4
* 5.1 or 7.1 channels
What I have been considering (leaning towards the Sherwood)
* Sherwood R-904N
* Harman AVR-700
* Marantz NR1403
Please help, what is the best solution and no thanks, I'm not replacing my media console.
PawnPower is offline
post #2 of 4 Old 01-04-2013, 04:57 PM
jdsmoothie's Avatar
Quoted: 12551 Post(s)
Liked: 5738
Due to the limite clearance above the AVR, rather than placing the fans on top of the AVR, you may be better served using them to the rear of the AVR to exhaust the warm air coming from the unit. Can't really make a specific AVR recommendation without knowing the specs of the media console.
jdsmoothie is online now
post #3 of 4 Old 01-04-2013, 05:48 PM
afrogt's Avatar
Quoted: 1093 Post(s)
Liked: 782
that media console doesn't look very deep.
I'd think I'd want more than 3 HDMI inputs just in case you get another device. Go with the Marantz as it has 6 HDMI inputs. don't know enough about the Sherwood unit to recommend it.
Afro GT
afrogt is offline
post #4 of 4 Old 01-07-2013, 06:53 AM - Thread Starter
PawnPower's Avatar
Space for the AVR is 23.25" W, 6" H, 15" Deep. So the only dimensional issue on the console is the height.
