Tower speaker setup on AVR when using subwoofer also - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-04-2013, 11:55 PM - Thread Starter
mpovolo's Avatar
My receiver recommends that I set my tower speakers at the front to Full and large. Should I not be setting it to 80Hz small so that bass is sent to the sub?
thanks
mpovolo is offline
post #2 of 10 Old 01-05-2013, 03:24 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
That is a standard recommendation that most tower speaker mfrs will make as they are ignoring any bass management done by the AVR. Whether you follow that advice really depends on the capability of your front mains, but in most cases, yes, you should be setting them to SMALL/80Hz.
jdsmoothie is offline
post #3 of 10 Old 01-05-2013, 03:58 AM
mliebs8's Avatar
I keep mine set to small with the crossover at 80hz but the people at KEF keep telling me to change it to large for the towers. I have the Q900's but it still seems odd to me. The peopIe at SVS said to keep them at small and crossed over at 80hz. I may try it just to try it though.
mliebs8 is offline
post #4 of 10 Old 01-05-2013, 04:05 AM
pokekevin's Avatar
Liked: 102
Try both and see what you like. Just remember that the position of the speakers may be good for imaging but not good for bass (the subwoofer!)
pokekevin is offline
post #5 of 10 Old 01-05-2013, 07:17 AM - Thread Starter
mpovolo's Avatar
Thanks all. I will try small 80Hz.
mpovolo is offline
post #6 of 10 Old 01-05-2013, 07:19 AM
jdsmoothie's Avatar
Liked: 5502
By all means ... you should always try various settings to determine which is ideal for your ears in your personal environment as the generally suggested settings may not apply to you. smile.gif
post #7 of 10 Old 01-05-2013, 09:23 AM
jclif77's Avatar
I tried to crossover my mains at 80hz and the bass all but disappeared. My avr crossed the towers at 40hz and the bass comes alive...
jclif77 is offline
post #8 of 10 Old 01-05-2013, 12:38 PM
jdsmoothie's Avatar
Liked: 5502
If you are using a separate sub, then those lower frequencies should have passed to the sub. You may just be used to bloated bass which some prefer, otherwise, have you done a sub crawl to determine the most ideal location for the sub in your room?
http://www.youtube.com/watch?v=AV3oLLMgS-M
post #9 of 10 Old 01-05-2013, 04:40 PM
JD in NJ's Avatar
Liked: 36
Also, is there a crossover/Low Pass Filter switch on the back of your sub, and is it set to bypass it? If not, is there a dial to set the LPF point and is it turned up all the way?
JD in NJ is offline
post #10 of 10 Old 01-05-2013, 10:37 PM - Thread Starter
mpovolo's Avatar
I have phase 0 or 180, volume, and dial which i set all the way up to like 120Hz
mpovolo is offline
