Enough power - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-05-2013, 11:02 AM - Thread Starter
pbaker's Avatar
Hello,
I have a older Yamaha AX-596 100rms 145 max. I was wanting to replace my Athena AS F2s with Cerwin Vega CLS-215 my question is this amp enough power for these speakers or will i need to add an amp.If i need to add is there one that's not terribly expensive.
pbaker is offline
post #2 of 3 Old 01-05-2013, 11:12 AM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
According to this review the CV's are very easy to drive, so your Yamaha integrated amp should be fine.
http://www.theabsolutesound.com/articles/tested-cerwin-vega-cls-215-loudspeaker/
Give it a try and if you find you need more power then add an amp. I certainly wouldn't buy an amp first w/o testing the speakers with just your Yamaha.
Afro GT
afrogt is online now
post #3 of 3 Old 01-05-2013, 11:35 AM - Thread Starter
pbaker's Avatar
thank you very much for your opinion,I appreciate it very much.
pbaker is offline
