Onkyo NR515 doesn't show prologic or DTS options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-05-2013, 11:37 AM - Thread Starter
tainle's Avatar
Hi
How can I turn prologic and dts ability to show on the dimmer when playing music? it used to show and allowed me to select pllx, neo6, dolby ex...i didn't change my input method (hdmi) or anything like that. all i did was update firmware and add 2 new satellite to make it a 7.1 system. Audyssey doesn't show could mean the reason i can't select pllx and dts for music. audyssey does show up when playing movie that support DD and DTS.
so how can i enable that? thanks
tainle is offline
post #2 of 12 Old 01-05-2013, 11:41 AM
jdsmoothie's Avatar
Quoted: 12110 Post(s)
Liked: 5511
When you add additional speakers to your setup, then you need to run Audyssey again to EQ the new speakers.
jdsmoothie is online now
post #3 of 12 Old 01-05-2013, 12:00 PM - Thread Starter
tainle's Avatar
what do you mean run audyssey again? i did run the auto calibration. audyssey is option 4.1 in option and audyssey is ON. auto calibration change the level of my all speakers to around -6dB to -12dB. i am not sure this disabled Audyssey Volume?
tainle is offline
post #4 of 12 Old 01-05-2013, 12:01 PM
jdsmoothie's Avatar
Liked: 5511
Let me put it another way .... has Audyssey been run with the 7.1 configuration?
post #5 of 12 Old 01-05-2013, 12:11 PM - Thread Starter
tainle's Avatar
Maybe not because I don't understand your question about running audyssey for 7.1. can you give me some step to run it? thanks
tainle is offline
post #6 of 12 Old 01-05-2013, 12:20 PM
jdsmoothie's Avatar
Liked: 5511
Originally Posted by tainle View Post
Hi
If you started with a 5.1 setup and ran Audyssey, then the 5.1 setup got EQ'd. Note however, that with a 5.1 setup the bolded surround modes you indicate were available, would in fact NOT be available but rather would only be available after you added the additional two speakers making it a 7.1 setup and then running Audyssey again to add them to the configuration. So again, when you ran Audyssey, did you have a 5.1 or 7.1 setup?
post #7 of 12 Old 01-05-2013, 01:12 PM - Thread Starter
tainle's Avatar
i have a 7.1 setup ran and saved the setting at the end. when the first time i plug in the microphone to do the calibration. it asked me to place the micro on 3 different location which i did. the second time i run it which the addition of two speakers, it only did the test 1 time i didn't have to place the micro on 2 more locations. i thought thats strange. note that i don't have output to tv screen. i just do everything by looking at the dimmer.
tainle is offline
post #8 of 12 Old 01-05-2013, 01:18 PM
jdsmoothie's Avatar
Liked: 5511
Suggest you reset the microprocessor (see Troubleshooting section in your Owner's manual) and start Audyssey all over again.
post #9 of 12 Old 01-05-2013, 02:06 PM - Thread Starter
tainle's Avatar
I will reset my AV receiver following the manual instruction and hope this will change anything.
tainle is offline
post #10 of 12 Old 01-05-2013, 02:07 PM - Thread Starter
tainle's Avatar
also i notice that if i select COAX input source the prologic iix does appear but not hdmi input source which i use frown.gif
tainle is offline
post #11 of 12 Old 01-05-2013, 02:42 PM - Thread Starter
tainle's Avatar
If you can’t resolve the issue yourself, try resetting the
AV receiver before contacting your Onkyo dealer.
To reset the AV receiver to its factory defaults, turn it
on and, while holding down CBL/SAT, press
􀀙ON/STANDBY. “Clear” will appear on the AV
receiver’s display and the AV receiver will enter
standby mode.
i followed this instruction but it doesn'tseem to work frown.gif... i think that prologic and dts neo6 are all 7.1 channel upscale output from lower channels like 5.1 and lower. since i set 7.1 surround in my speaker setup in my computer. prologic and dts neo wouldn't appear because it is already set up as a 7.1 by windows? i look at the signal "information" on my receiver it say MCH PCM 7.1. could this be the reason i am not getting the prologic and dts options not appear on the dimmer? well i couldnt select them so it couldnt be on smile.gif
tainle is offline
post #12 of 12 Old 01-05-2013, 03:51 PM - Thread Starter
tainle's Avatar
yes it seem that was the case. i set the speaker to 5.1 and under the prologic and dts does appears since it work to upmix channels. thanks:eek:biggrin.gif
tainle is offline
Onkyo Tx Nr515
