Need some help, new tv not compatible with surround sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-06-2013, 02:53 AM - Thread Starter
Cradle6's Avatar
Hey everyone, first time posting.
So I bought a Vizio M3D0KD a couple days ago, and I've been struggling to connect it to my surround sound system, a panasonic pt950. The problem is, I've been connecting this system to my old tv with the red and yellow RCA cables (not actual surround sound, I know). The Vizio I bought only has optical audio out, something that the audio receiver does not have (only RCA and HDMI).
My question is, what is my best and most inexpensive option to get this system working? If possible, I'd like to finally use actual surround sound.
Should I just buy a new audio receiver, and if so, will it be compatible with all my speakers? (the pt950 has 3 wired speakers and 2 wireless speakers; the white and blue wire ones).
Or is there a better solution that I'm not seeing?
I really appreciate the help, as I'm not very knowledgable about this subject.
Cradle6 is offline
post #2 of 12 Old 01-06-2013, 03:10 AM
jdsmoothie's Avatar
Quoted: 12181 Post(s)
Liked: 5549
jdsmoothie is offline
post #3 of 12 Old 01-06-2013, 09:18 AM - Thread Starter
Cradle6's Avatar
Wouldn't that just be stereo, not 5.1?
And also, doesn't that only work with stereo signals??
Cradle6 is offline
post #4 of 12 Old 01-06-2013, 10:33 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
In all honesty I think its time to replace your Panasonic PT950 with a real A/V receiver with HDMI inputs.
This is why I never recommend All in One systems like that to anyone...they lack inputs and connectivity.
Afro GT
afrogt is online now
post #5 of 12 Old 01-06-2013, 10:49 AM
Ross Ridge's Avatar
Liked: 81
You won't be able to use the wireless receiver or the subwoofer with a new receiver, but you can reuse the other speakers with a new receiver that supports 4 ohm speakers.
Ross Ridge is offline
post #6 of 12 Old 01-06-2013, 11:01 AM
jdsmoothie's Avatar
Liked: 5549
Correct, but more than likely only a stereo signal is being output from the optical audio output on the TV. Your Panasonic then simulates 5.1 from that stereo input.
post #7 of 12 Old 01-06-2013, 02:56 PM - Thread Starter
Cradle6's Avatar
Would it be better to just get a digital to analog converter or sell this system and just buy a $200 sound bar/sub? (something like this)
I just can't afford to do much more than that. Right now I'm dealing with the TV's speakers, and they're just dreadful.
Cradle6 is offline
post #8 of 12 Old 01-06-2013, 03:00 PM
jdsmoothie's Avatar
Liked: 5549
If you're satisfied with the audio from the current setup for now, might as well just get the converter and save up for a newer AVR and better 5.1 setup in the future.
post #9 of 12 Old 01-06-2013, 03:03 PM - Thread Starter
Cradle6's Avatar
Why wouldn't the subwoofer work by the way?
It is wired.
Cradle6 is offline
post #10 of 12 Old 01-06-2013, 03:24 PM
Ross Ridge's Avatar
Liked: 81
AV receivers these days only support powered subwoofers directly. Your subwoofer is unpowered, and so you would need to buy an external amplifer to drive it and it's probably not worth it.
I think you'd be better off saving your money until you can afford a half-decent entry level system so you're not making the same mistake again.
In the meantime according to the manual for the Vizio M3D470KDE it does in fact have a stereo analogue output that you can hook up to your existing receiver. It uses a 3.5mm headphone jack instead of RCA connectors. All you need is a simple 3.5mm to RCA cable.
Cradle6 likes this.
post #11 of 12 Old 01-06-2013, 11:09 PM - Thread Starter
Cradle6's Avatar
I took your advice and hooked up the unit with an RCA/3.5 mm adapter.
Only (expected) issue is that only 2 speakers play any sound. Is there anyway to "simulate" surround sound with stereo? As in, I know my subwoofer is basically useless now, but can I play sound over all 5 speakers using stereo?
Really appreciate help.
Cradle6 is offline
post #12 of 12 Old 01-07-2013, 04:22 AM
jdsmoothie's Avatar
Liked: 5549
On the Panasonic, you can use the Pro Logic surround mode to simulate 5.1 from the 2.0 source.
Cradle6 likes this.
