Looking for a 300 watt monoblock. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-06-2013, 11:41 AM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Have been doing some research and cant seem to come by any amps that can push 300 watts at 8ohm. I'm seeing ones that will do 200 or 500.
Anyone know of any? It will be powering a Paradigm Studio CC-690.
TenTonBass is offline
post #2 of 3 Old 01-06-2013, 12:08 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
According to the manufacturer that speaker has a maximum input power of 210 watts. It has a suitable amplifier range of 15-300 watts. I think this is why you're looking for a mono block amplifier with 300 watts. Those numbers are a little confusing. The truth is that speaker will never use 300 watts. If you really want a mono block for that speaker I think a 200 watt mono block would be plenty of power. With peaks a 200 watt mono block will usually make more power. Here are a couple of mono blocks that would work.
http://shop.emotiva.com/collections/amplifiers/products/xpa100
http://www.outlawaudio.com/products/2200.html
Secret Squirrel is offline
post #3 of 3 Old 01-06-2013, 12:45 PM - Thread Starter
TenTonBass's Avatar
Quoted: 16 Post(s)
Yeah that sounds about right. Thanks!
