Denon 2312 can't get sat/cable audio in zone 2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 01-06-2013, 03:48 PM - Thread Starter
shooza's Avatar
Hi everyone, new to this game. I have a denon 2312 and can't figure out how to play my sat/cab audio in zone 2. Can play everything else (ie airplay, radio etc) but can't get audio in zone 2 for my foxtel.
shooza is offline
post #2 of 21 Old 01-06-2013, 03:53 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
You will need to connect an analogue connection from your DVR to the AVR in order to get it to zone 2. Most all AVR's cannot play a digital source in other zones other than the main zone.
Secret Squirrel is offline
post #3 of 21 Old 01-06-2013, 04:01 PM - Thread Starter
shooza's Avatar
Sorry for my ignorance but is the DVR my sat/ cab box.
shooza is offline
post #4 of 21 Old 01-06-2013, 04:02 PM
Quoted: 44 Post(s)
Liked: 39
Yes, DVR is digital video recorder or called a set top box if you don't have the recording capability.
post #5 of 21 Old 01-06-2013, 04:07 PM - Thread Starter
shooza's Avatar
Thanks, does that mean I have to get a digital to analog converter from the DVR to the AVR.
shooza is offline
post #6 of 21 Old 01-06-2013, 04:50 PM
Quoted: 44 Post(s)
Liked: 39
No, Your DVR or set top box should have analogue audio connections. Just double wire it to the AVR.
post #7 of 21 Old 09-03-2013, 01:15 AM - Thread Starter
shooza's Avatar
Hi everyone, all of a sudden my airplay icon does not appear on any of my apple devices or my computer. I have recently updated my modem to a netgear 3700. Any ideas appreciated. I have a Denon 2312
shooza is offline
post #8 of 21 Old 09-03-2013, 12:04 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
jdsmoothie is offline
post #9 of 21 Old 09-07-2013, 01:54 AM - Thread Starter
shooza's Avatar
Hi thanks tried all of that and hasn't worked. It seems to have happened since the new modem. Netgear DGND3700. Could that be the problem.
shooza is offline
post #10 of 21 Old 09-07-2013, 02:10 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Your new router http://www.netgear.com/home/products/wirelessrouters/high-performance/dgnd3700.aspx, yes router and not modem, probably changed and possibly invalidated, the IP addresses of all or at least some of your equipment, wireless or not.
That probably means that you need to reinstall anything that stopped working. Open the user manual for the 2312 and pretend you are putting it on your LAN for the first time. Try to leave as much of the IP configuration dynamic as you can.
arnyk is offline
post #11 of 21 Old 09-07-2013, 03:45 AM - Thread Starter
shooza's Avatar
Sorry I don't understand.
shooza is offline
post #12 of 21 Old 09-07-2013, 07:10 AM
jdsmoothie's Avatar
Liked: 5502
As Arny has indicated, simply refer to your Denon 2312 owner's manual and do the network setup as you had to do with the first router.
post #13 of 21 Old 11-11-2013, 01:53 AM - Thread Starter
shooza's Avatar
He'll everyone. Could you please tell me which is the best modem router for a Denon 2312 especially for using airplay.
shooza is offline
post #14 of 21 Old 11-11-2013, 03:55 AM
jdsmoothie's Avatar
Liked: 5502
Here's a list of what other's have used ...
Router
Cisco WRT-100
Cisco E3200
Linksys BEFSX41
Netgear N600 3400v2
Netgear WNDR-3800
Netgear WNDR4500
Airport Extreme
Bridge (connected to AVR provides wireless connection to the home's wifi router)
Cisco WRT-54G
TRENDnet TEW-640MB
Airport Extreme
Airport Express
Linksys WET610N
Netgear WN2000RPT - 4 port
Netgear WN2500RP
D-Link DAP-1522
Other
Netgear XAVB5004 Powerline Network Adapter (4-port) (on AVR set Network Standby/IP Control to ON/Always ON)
D-Link Powerline Adapter
Belkin Video Link 3 (w/static IP)
D-Link 8-Port Gigabit Switch (DGS-1008G)
post #15 of 21 Old 11-11-2013, 04:18 PM - Thread Starter
shooza's Avatar
Thanks mate but what about an all in one modem router.
Craig
shooza is offline
post #16 of 21 Old 11-11-2013, 06:26 PM
jdsmoothie's Avatar
Liked: 5502
Not sure why you want a combination bridge/modem if you already have a modem and the Netgear 3700? What you likely need is another modem set up in bridge mode wired to the 2312 which will connect to the Netgear 3700. In fact you could likely just use another Netgear 3700 in "bridge" mode to get the job done.
post #17 of 21 Old 11-11-2013, 06:58 PM - Thread Starter
shooza's Avatar
The reason I ask is because I can't get the blasted airplay to work with the Netgear 3700 and I've read it's because of the router side of things. I had an old Belkin Surf 300 and everything used to work fine. It's only since I got this 3700 things have gone haywire. If u got a airport express would that work. Could i play my iTunes music and also be able to play music from my sat box from the music channel.
Craig
shooza is offline
post #18 of 21 Old 12-18-2013, 12:38 AM - Thread Starter
shooza's Avatar
Hello everyone I have now updated to Denon 2313 and can't figure out how to play movies that are on my portable hardrive with USB connection. I can get picture if I plug into my tv but unsure how to get sound from Denon. Help appreciated.
shooza is offline
post #19 of 21 Old 12-18-2013, 06:09 PM
jdsmoothie's Avatar
Liked: 5502
You need to check your TV's Owner's manual to learn if it will output audio from the optical audio output or HDMI(ARC) if it is HDMI(ARC) capable.
post #20 of 21 Old 12-18-2013, 09:51 PM - Thread Starter
shooza's Avatar
Hi thanks the tv is arc capable. Tv is connected to 2313 by arc and ps3 and wii are connected to the 2313. Everything works fine just wondering how to connect the USB hardrive to play movies. Picture ok but no sound through the 2313
shooza is offline
post #21 of 21 Old 12-19-2013, 01:09 AM
jdsmoothie's Avatar
Liked: 5502
USB must be connected to the TV for video and then pass the audio back to the 2312 via either HDMI(ARC) or optical cable.
Denon Avr 2312ci Receiver , Denon
