Crazy Loud Popping When Starting Up New Theater System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-07-2013, 08:05 PM - Thread Starter
bentout12's Avatar
I recently set up a home theater system that's been having one issue since the beginning. Pioneer VSX 822k receiver with a bose acoustimass 10 5.1 audio system.
It seems to work fine, except when I turn everything on after it's been off for awhile, the speakers throw out crazy loud static/popping sounds. The sounds keep going even if I turn the volume to zero. If I turn the volume up, I can hear the audio source underneath the static/popping. But the static/popping stays the same at any volume setting. After a few minutes, it starts to go away. This only happens after the system has been off for awhile. If I turn it off and back on again, there is no problem.
I think it might only happen when I set the source to my cable box, but I'm not sure. I'm going to have to try different sources whenever it happens again.
Anyone know what the problem is?
bentout12 is offline
post #2 of 10 Old 01-07-2013, 08:26 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Just burn the Bose, and your problems will go away.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #3 of 10 Old 01-08-2013, 05:36 AM - Thread Starter
bentout12's Avatar
Any solutions? I don't want to return the speakers without verifying they are the problem.
post #4 of 10 Old 01-08-2013, 06:02 AM
gregzoll's Avatar
Liked: 33
Try a different set of speakers. Bet you it is the Bass module that is causing it, since the speakers feed off of it.
gregzoll is offline
post #5 of 10 Old 01-08-2013, 12:06 PM - Thread Starter
bentout12's Avatar
Does it sound like it is the speakers and not the receiver or cable box?
I was thinking of this set as an alternative.
http://www.amazon.com/gp/aw/d/B001R70ZMI
How does it look? It's cheaper than the Bose setup, but I hear Bose is overpriced anyway.
post #6 of 10 Old 01-11-2013, 01:34 PM - Thread Starter
bentout12's Avatar
It wasn't the Bose. I switched to a 5.1 Def Tech Pro Cinema 600 and it's giving me the same problems. I've tried setting my cable box to use different HDMI inputs and it still does the same thing. I also noticed the loud popping/hissing causes my TV to power off when it happens.
What next?
post #7 of 10 Old 01-11-2013, 02:52 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The answer hangs on the name of the device that removing fixes the problem.
arnyk is offline
post #8 of 10 Old 01-11-2013, 06:53 PM - Thread Starter
bentout12's Avatar
Not totally sure what that means. No one has a suggestion?
post #9 of 10 Old 01-11-2013, 09:12 PM - Thread Starter
bentout12's Avatar
Just noticed that the popping came back when I purchased a movie on demand through my cable service. It definitely seems like the cable box is the culprit, or an incompatibility between the box and the receiver.
Any suggestions?
post #10 of 10 Old 01-11-2013, 10:33 PM
Prochambers's Avatar
I would go back thru everything to make sure that all connections are intake. Check for loose wires or connectors. Also, check internal settings on the receiver and the cable box in case something is not compatible. Advice: I would NOT turn the volume up as before until you have sorted out the problem. The last thing you would want to do is blow your speakers!!!
"If you lend someone $20.00 and never see that person again, it was probably worth it!"
Equipment:
Classe SSP-600 Processor
Rotel RMB-1095 Amplifier
Pioneer PRO-151FD 60" Plasma
Oppo BDP-95 Blu Ray Player
Paradigm Studio 100 Fronts/Studio 40 Rears/Studio CC-450 Center
Mirage BPS-400 Subwoofer
Prochambers is offline
