Which Receiver to use for a processor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-08-2013, 11:23 AM - Thread Starter
alan_ct's Avatar
It seems like the current crop of budget processors may be plagued with problems again...I am thinking of just using a receiver to decode to my power amps...I was looking at the current crop of receivers with pre outs....I'd like to stay at 500$ max...It can be new, used or refurb, but have all of the latest surround lossless formats...Anyone have any experience with the Yamaha Adventege receivers? What other choices are out there? Thanks!
alan_ct is offline
post #2 of 9 Old 01-08-2013, 11:43 AM
beboram's Avatar
I am using refurb Marantz SR5007 as a processor. Bought refrub with 1 year factory warranty..
beboram is offline
post #3 of 9 Old 01-08-2013, 11:51 AM
Kamikaze13's Avatar
Quoted: 99 Post(s)
Liked: 49
Everyone will tell you how reliable Yamaha is but I've had mine and 3 friends all had theirs malfunction.
I would buy Yamaha again but for now I went to Onkyo, who many will say have major quality control issues.
I wouldn't hesitate to go with the Yamaha Aventage line or the Onkyo 609 or 809 which is pushing your budget however.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
post #4 of 9 Old 01-08-2013, 11:59 AM - Thread Starter
alan_ct's Avatar
Would this be a good choice over the Yamaha for 200.00 more? PS Im using a 10 year Atlantic Technology processor now so anything will be a big step up! http://www.accessories4less.com/make-a-store/item/MARSR5006/Marantz-SR5006-AV-Receiver-with-Networking-and-AirPlay/1.html
alan_ct is offline
post #5 of 9 Old 01-08-2013, 12:22 PM - Thread Starter
alan_ct's Avatar
alan_ct is offline
post #6 of 9 Old 01-08-2013, 01:21 PM
Stephen Hopkins's Avatar
Unless there's some extremely esoteric feature differences someone wants to point out, the NR709 and SR5006 look to pretty much neck-and-neck feature wise. Both have all the modern audio codec support, HDMI 1.4 for 3D and ARC, PLIIz and DSX for height/wide channels, MultEQ XT room correction, etc. The Marantz has AirPlay for streaming audio from iOS devices which the Onkyo lacks. Both have learning remotes, but the Onkyo remote also supports basic macros/activities.
The NR709 would probably be my choice for a an AVR-as-Pre/Pro these days, unless you want to spend $250 more for the NR818 to get MultEQ XT32 room correction, and the main benefit there is more EQ points when running dual subwoofers. It's a shame that the newer NR717 drops the room correction all the way down to 2EQ, making it much less compelling as a Pre-Pro.
Stephen Hopkins is offline
post #7 of 9 Old 01-08-2013, 01:57 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
I don't think you'll find anything new for $500. I know I couldn't find anything.
An Aventage refurb (A800) is what I went with. It's only been a month, but I am thrilled so far. Adventage refurbs come with 2 year warranty (according to OneCall).
David
crussader is offline
post #8 of 9 Old 01-08-2013, 02:35 PM - Thread Starter
alan_ct's Avatar
Thanks...Do you think the processors are similar in the RX series receivers?
alan_ct is offline
post #9 of 9 Old 01-09-2013, 08:49 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
My previous receivers were RXs. I don't hear a significant sound difference between them and the Adventage. The Adventage is more about features (like the pre-outs) and build quality (50% longer warranty).
David
