Is there a way to send music from my computer to my receiver Onkyo TX-SR803 wirelessly? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-08-2013, 05:16 PM - Thread Starter
Replacement's Avatar
The receiver is older so it doesn't have internet connection and I have music on my computer across the room.
Is there some kind of an adapter to allow this?
"Having a smoking section in a restaurant is like having a peeing section in a pool."
Replacement is offline
post #2 of 8 Old 01-08-2013, 05:20 PM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5518
Sure ... just connect an Apple TV or Airport Express to the 803.
jdsmoothie is online now
post #3 of 8 Old 01-08-2013, 08:08 PM - Thread Starter
This is in my office. I do not have a tv or ps3 or anything like that in there.
I was hoping to find some kind of wireless RCA connection, it is only 10' as a straight.
post #4 of 8 Old 01-08-2013, 08:27 PM
afrogt's Avatar
Quoted: 1054 Post(s)
Liked: 756
Do you have a wireless router in your office?
If so, I think the airport express would work for you. It has an audio output that you could connect to the receiver.
http://www.apple.com/airportexpress/
Afro GT
afrogt is online now
post #5 of 8 Old 01-08-2013, 08:53 PM - Thread Starter
I have a wired router in there...
I was hoping to find something less expensive/simpler if that exists.
post #6 of 8 Old 01-08-2013, 09:38 PM
marvelousmarvyd's Avatar
Hello, I/ am also in the same boat as the op, can /i use the 1st gen apple tv with an older receiver (Teac Reference AG-h300mk3).
marvelousmarvyd is offline
post #7 of 8 Old 01-08-2013, 09:55 PM
afrogt's Avatar
Liked: 756
Well the simplest and cheapest thing to do is run an audio cable along the baseboard from your computer to the receiver.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021802&p_id=645&seq=1&format=1#largeimage
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021815&p_id=5612&seq=1&format=1#largeimage
Two cables would cost you about $3.50 plus shipping.
If your computer happens to have digital optical output then use this cable instead for under $3.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10229&cs_id=1022901&p_id=1448&seq=1&format=1#largeimage
If you must have a wireless solution then maybe someone else will chime in with an idea.
Afro GT
post #8 of 8 Old 01-09-2013, 02:49 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I think this is what the OP might be looking for.
http://www.amazon.com/gp/product/B002BDU95A/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00822J8VU&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0HRM60338VSWFE9ZMSD9
It is a wireless transmitter and receiver. The receiver connects to the AVR via RCA or 3.5mm and the transmitter connects to the PC via USB port. There are lots of them that need a Bluetooth connection but this one is 2.4 GHz RF, which should work a lot further away than 6 feet. If you want one that will also work with a PMP or Smartphone, then you'll need a wi-fi or Bluetooth with a USB dongle for your computer.
I haven't tried anything like this myself because I'm already net-connected to my PCs or I can just jack my PMP or Tablet right into my AVR using HDMI or USB.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Onkyo Tx Sr803 Av Receiver 7 1 Channel , Onkyo Tx Sr803b Home Theater Receiver Black
