Wanting to buy Onkyo nr 818 or denon avr-3313 need advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-09-2013, 11:09 AM - Thread Starter
Havolice's Avatar
Hello
i been wanting to replace my 609 onkyo with a 818 or a denon 3313
i will give you guys a list of what i want and use
i use the reciever on
Samsung ps60e6500 tv
onkyo bd809
HTPC powered with a ati card *my 609 had issues with 24p on the ati card tv whould go on and off continuesly was fixed after a update*
wii u
xbox 360
ps3
and digital television
i got JBL es series speakers front speakers support bi amping * so i kinda want to try this*
a klipsch subwoofer *i forgot the type number can insert this later*
wel i want this to work i know my speakers arent the best i bought them on a impulse same as the 609 but now i want some good legit advice instead of a shop worker hehe.
my expectations is great surround in movies good subwoofer support.
i actualy want it to work not have issues for months like i had with my htpc.
i want to finaly sit back and enjoy the equipment without second guesing it like i am doing now with the 609.
in short i kinda want to know what the pro's and cons are of both, and what iether excels and doesnt excell in.
i hope you guys can help me with some advice ^^
Havolice is offline
post #2 of 10 Old 01-15-2013, 01:08 AM
Ajinu Sen's Avatar
go for onkyo 818..if u want better sound quality and more features
Ajinu Sen is offline
post #3 of 10 Old 01-15-2013, 01:25 AM
InfernoST's Avatar
I have the 818 and am very pleased with its performance however there is a reported bug with 24fps which to my knowledge is being worked on by Onkyo. My displays don't support 24fps so this bug doesn't affect me.
InfernoST is offline
post #4 of 10 Old 01-15-2013, 12:00 PM
Ajinu Sen's Avatar
what is 24p problem..is this affect video.. when playing bluray movies..
post #5 of 10 Old 01-25-2013, 08:00 AM
Mike Butny's Avatar
Quoted: 565 Post(s)
Liked: 998
It affects 59.94 material as well, just like I stated on the onkyo forum.
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7009 Receiver, 3-Marantz Ma700 and 2-Ma6100 mono blocks, 9.2 set-up, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, Infinity ( soon to be replaced by B&W ) bookshelf Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, PSA S3600I & S3000I subs, Richard Grey, Monster Power, and Panamax powerline conditioning/surge protection.
Mike Butny is online now
post #6 of 10 Old 01-25-2013, 09:07 AM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
I currently have a Denon 3313 (though I'm probably going to get a 4520). The 3313 is a great AVR and sounds fantastic. I haven't tried the 818 in my setup but I actually replaced an Onkyo 876 with the Denon 3313.
In comparing the Denon 3313 to the Onkyo 818 I see the following advantages/disadvantages:
Denon 3313:
Pros:
- Built in airplay
- No 24fps bug
- Overall very polished operation (very quick HDMI switching and syncing when the resolution is changed)
Cons:
- MultiEQ XT versus XT32 for 818
- May have slightly less power than the 818 as the 818 weighs well over 10 pounds more - on the other hand tests of last year's Denon 3312 and Onkyo's 1009 indicate that any differences would be small - e.g. with 7 channels driven I believe hometheater.com reported 86wpc for the Onkyo and 80wpc for the Denon - an irrelevant difference that will yield no measurable difference in output (you would need 160 watts to get a 3DB increase).
The Onkyo does look like a better value on paper but it features many redundant features (e.g. THX Loudness Plus and Dolby Volume accomplish the same thing as Audyssey Dynamic EQ/Volume) that I know I wouldn't use. For me it was easy as the 818's 24fps bug was a showstopper. On the other hand, XT32 is great but in the 818 it doesn't include SubEQ HT like it does on the 1010/3010/5010 so I didn't find it as compelling - certainly not enough to dismiss the 24fps bug.
When you think about it, the 24fps bug will be visible but the the benefits of XT32 you would have to be in a position to do an A/B comparison so to me it's easy to see which advantage/disadvantage is more important.
Anyway, that's my $.02
EVT is offline
post #7 of 10 Old 01-25-2013, 11:30 AM
bhawes's Avatar
Go with the Integra DTR 40.4 or DTR 50.4 its onkyo high end receivers.
bhawes is offline
post #8 of 10 Old 01-25-2013, 04:24 PM
Mike Butny's Avatar
Quoted: 565 Post(s)
Liked: 998
Well if Onkyo's new firmware fixes the VP bug then it maybe the best bang for buck receiver on the market.
post #9 of 10 Old 01-25-2013, 06:00 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 37
So the 818 STILL has the 24p bug? Any other reliability problems with the 818?
I have heard the Onkyo sound a little bass heavy in comparision to the neutral Denon.
Newbie01 is offline
post #10 of 10 Old 01-26-2013, 05:13 AM
InfernoST's Avatar
There is a firmware update being tested by some of the members to see if the problem is fixed, other than that I am not aware of any other issue with the receiver and am very pleased with my 818.
Onkyo Tx Nr818 , Denon Avr 3313ci Receiver
