do they make a 7 channel male to male rca cable from a oppo blu ray player to a 7 channel amp? - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2013, 06:02 PM - Thread Starter
larryep's Avatar
having trouble finding such a cable.
thank you
larry
larryep is offline
Old 01-09-2013, 07:21 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
you can probably find them but more than likely they'll cost more than this solution.
Monoprice 6 foot 5 RCA component video/audio cable
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023501&p_id=2773&seq=1&format=1#largeimage
Monoprice stereo cable
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021814&p_id=2864&seq=1&format=2
Total will cost you less than $20. You could also just get 4 of the stereo cable which gives you 8 connectors.
This cable has 6 RCA connectors, then you only need to add one more.
http://www.ramelectronics.net/product.aspx?zpid=3630
If you want to spend more money for something fancy get this.
http://www.ramelectronics.net/product.aspx?zpid=3031
Afro GT
afrogt is offline
Old 01-10-2013, 05:55 AM
JD in NJ's Avatar
Liked: 36
You could also go BlueJeans: http://www.bluejeanscable.com/store/6channel/index.htm
Not terribly cheap, but not horrifically expensive either, and they use high quality components and wire. You can get the exact length you need, too. A seven conductor six foot cable would be about $135. Which, frankly, is enough that while I keep that site handy, I continue to use older decent quality RCA cables.
JD in NJ is offline
