Denon Avr 987 Help!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-11-2013, 08:53 AM - Thread Starter
tripack1's Avatar
I have a Denon 987 hooked up to my LG TV. I can get my DVD to play video on the tv and the audio goes to the surround sound speakers fine but when I switch to TV on the receiver I can only get audio on the speakers no video on the screen. I can't figure out what I am doing wrong. I switched the TV to the correct input and still nothing...
tripack1 is offline
post #2 of 4 Old 01-11-2013, 06:15 PM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5517
What source are you using for TV and how is it connected?
jdsmoothie is online now
post #3 of 4 Old 01-11-2013, 07:27 PM - Thread Starter
tripack1's Avatar
Comcast cable box and it is connected by coax cables..
tripack1 is offline
post #4 of 4 Old 01-12-2013, 04:05 AM
jdsmoothie's Avatar
Liked: 5517
So then you have the cable box HDMI connected to the TV and a coax digital cable from the cable box to the AVR for surround sound? And you're getting audio from the surround speakers, so the AVR is working as it should. If you have selected the correct cable box HDMI input on the TV (ie. not the HDMI from the 987) and still see no video from the cable box, you may want to try other HDMI inputs on the TV, otherwise perhaps the cable box is defective.
