Marantz SR5007 or Marantz SR7005 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-11-2013, 10:31 AM - Thread Starter
gelly's Avatar
I see the priced has compressed between the two quite a bit. Which is a better receiver for my needs? Planning on going with LG 55LM9600 and apple TV. Im current using Boston Acoustic satellite 5.1 system that about 12 yrs old that i will be replacing with similar sized system. Thanks
gelly is offline
post #2 of 9 Old 01-11-2013, 04:07 PM - Thread Starter
gelly's Avatar
If anyone has some thoughts on this I would greatly appreciate it. I'm trying to purchase one this weekend. Thx
gelly is offline
post #3 of 9 Old 01-11-2013, 05:12 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
As noted by the model number difference the 7005 is a few models above the 5007. Both use the same Audyssey MultEQ XT, and each offers features the other doesn't. So choose the one that best meets your feature/input/output requirements.
jdsmoothie is online now
post #4 of 9 Old 01-13-2013, 02:48 PM - Thread Starter
gelly's Avatar
Thank you. But what are the major differences ? I really liked the sr7007 over the sr5007, but if I can pick up a sr7005 that will spend like the sr7007 I'd prefer to save the $500-700. I was surprised of the sound difference in the 5007 vs the 7007 and to me the 7005 seemed like it had a better build quality.
gelly is offline
post #5 of 9 Old 01-13-2013, 03:12 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
What exactly does that mean, doesn't make sense to me?
Afro GT
afrogt is offline
post #6 of 9 Old 01-13-2013, 03:18 PM - Thread Starter
gelly's Avatar
Crazy spell check. Should be sound like.
gelly is offline
post #7 of 9 Old 01-14-2013, 07:58 AM - Thread Starter
gelly's Avatar
Has anyone checked these units out side by side to discern the major differences? I can only find the 7005 on line. Thanks
gelly is offline
post #8 of 9 Old 01-14-2013, 08:02 AM
XStanleyX's Avatar
Liked: 1269
You can compare them here:
http://us.marantz.com/us/Products/Pages/ProductComparison.aspx?CatId=AVReceivers&ProductId=SR5007|SR7005
XStanleyX is offline
post #9 of 9 Old 01-14-2013, 08:13 AM
XStanleyX's Avatar
Liked: 1269
I researched both before buying and chose the 7005. The features the 7005 has outweighed the 5007 for my wants/ needs.
Marantz Sr7005 Audio Video Receiver Black , Marantz Sr5007 Home Theater Av Receiver
