HK-1700 for $125 or Denon 1613 for $275? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 01-15-2013, 09:41 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I'm not sure the low-end audyssey is that much better than ezset. I'll agree the upper end x32 certainly is. With the same speakers in the same room both set up correctly there SHOULD be little to no difference between them.
lespurgeon is offline
post #32 of 44 Old 01-16-2013, 03:50 AM
jdsmoothie's Avatar
Quoted: 12340 Post(s)
Liked: 5631
Note that unlike Onkyo, Denon doesn't start with the low end version of Audyssey 2EQ which also cannot EQ the subwoofer, while folks generally notice a difference when using the MultEQ which is on the 1613. smile.gif
jdsmoothie is offline
post #33 of 44 Old 01-16-2013, 03:48 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
I read this forum and I decided on getting the 1613. Then I went to Best Buy and saw the HK1700 on an open box for $168. My knees buckled and I started sweating. I started seriously thinking about it, but then I remembered, I'm going to have this receiver a long time, do I really want to wish I had got the Dennon for a long time? I'm trying to decide now on the $199 1612 on accessories4less or the 1613 for $259. I'm an android guy and I don't care about airplay. I'm kinda leaning toward the 1612.
sojodave is offline
post #34 of 44 Old 01-16-2013, 03:54 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
This definitely isn't my first rodeo. I've had HK receiver, Sony, Pioneer, and I'm currently running an Onkyo 604. I love my 6 year old Onkyo 604, but I am interested with going with a different brand. My Onkyo 604 has 90 watts per channel and the Dennon 1612/1613 only has 75 watts. Will I notice a significant loss in power?
sojodave is offline
post #35 of 44 Old 01-16-2013, 07:29 PM - Thread Starter
butie120's Avatar
Quoted: 397 Post(s)
Liked: 76
I'm curious to see what others have to say about this. I guess I didn't pay much attention to the fact that the 1613 only had 75 watts a channel. What do you guys think?
butie120 is offline
post #36 of 44 Old 01-17-2013, 03:21 AM
jdsmoothie's Avatar
Liked: 5631
Nope. The difference of 15W will be moot, especially as on average the speakers are only drawing 5W/Ch at best. Doubling the power only results in a change in SPL of 3db which is just barely noticeable by most people. So if going from 75W to 150W is a 3db difference, then 75db to 90db is < 1W difference (ie. moot).
post #37 of 44 Old 01-17-2013, 07:21 AM
joe801's Avatar
Quoted: 94 Post(s)
Liked: 78
Is it possible to get both and see which one is best for you?
joe801 is offline
post #38 of 44 Old 01-17-2013, 07:27 AM
ensignlee's Avatar
Not to introduce more confusion by adding more choices, but have you scoured craigslist in your area yet? You'd be surprised at the great deals that came along.
I got a 1610 for $125 2 weeks ago which I thought was a good deal, but just two days ago I replaced it with a Denon 2310 for $110! With the savings, I just bought an appletv so I could have airplay.
That may end up being your best bang for buck solution?
Of course, if you have to use your $75 best buy bucks or want the security of knowing you can return it in 30 days no questions asked and want things new, I understand this may not be an option for you.
ensignlee is offline
post #39 of 44 Old 01-17-2013, 02:39 PM
Jim McC's Avatar
Quoted: 116 Post(s)
Liked: 58
When you audition a receiver from Craigslist, what specifically do you check/look for? Any tips? Thanks.
Jim McC is offline
post #40 of 44 Old 01-17-2013, 08:04 PM
sinkdrain's Avatar
I was torn between the exact same systems. After much research i decided on the 1700 and it has exceeded expectations. You will not read a review from anyone saying anything negative about the sound of the the 1700. It is warm powerful and detailed. I'd choose it over the 1613 even if the 1700 was selling the retail price of $599.
sinkdrain is offline
post #41 of 44 Old 01-17-2013, 08:49 PM
joe801's Avatar
Quoted: 94 Post(s)
Liked: 78
you would be surprised, trust me:) after owning the 700 & 1700. Sound is so much better from the 1613. Nothing bad to say about the 1700.
joe801 is offline
post #42 of 44 Old 01-19-2013, 04:00 PM - Thread Starter
butie120's Avatar
Quoted: 397 Post(s)
Liked: 76
Ugh! Waiting for the 1613 to go down in price is killing me. Trying to be patient is difficult sometimes...
butie120 is offline
post #43 of 44 Old 01-19-2013, 04:44 PM
Splicer010's Avatar
Liked: 39
You should SERIOUSLY check into the used/refurb market while waiting then. Takes the edge off and more often than not you will find a better AVR for the same or less than what you are looking to spend.
As for the 75 watts, believe it, that gets loud. Not crazy loud, but very loud just the same. Many times you will watch a movie with it 3/4's turned up and that will give slightly louder than 'normal' levels and is quite normal while still leaving headroom. Ebay can be great...an AVR 2310 (Denon) from there for under $130 shipped, 105 watts/ch there. My sister loves it. Was a grand when new.eek.gifwink.gif
Just food for thought...
Splicer010 is offline
post #44 of 44 Old 01-19-2013, 08:50 PM
afrogt's Avatar
Quoted: 1066 Post(s)
Liked: 773
Denon 1613 is currently $288 at Fry's. I was there this morning. Get Best Buy to price match.
Afro GT
afrogt is online now
Harman Kardon Avr 1700 5 1 Av Receiver , Denon Avr 1613 Receiver
