Anybody had problems with there SR7007 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-13-2013, 02:32 PM - Thread Starter
RMZguy151's Avatar
I just got my new SR7007 a few days ago and got it all hooked up, let me tell you I am very impressed with the overall sound quality of the unit compared to my last receiver. The only problem I am having, which I am curious if anybody else has had any issues with this, anyway, when I am watching TV through the cable box every 5-10 seconds (depending on the camera position during the broadcast) the picture gets pixilated like its trying to catch up or something, the pixilation only lasts less than a second. This problem only seems to happen when watching sports. I have checked all other tv's in my house that are on same program and they do not do this. I had a Yamaha RX-V565 previous to the Marantz and it did not have this problem at all using the same components (TV, cable box, HDMI cables) I don't know whats going on, I am not using cheap HDMI cables, I am either running Monster or Audioquest (low to mid level cables) I even tried switching them to see if it was the cable causing the problem. I also have tried switching HDMI channels in the back to see if it was the CBL/SAT channel that was causing it. Nothing has worked. Does anybody have any ideas? Is it a setting issue on my receiver? Do I need better quality HDMI's, do you think its a problem with the Receiver, could it be a interference issue? Any input would be much appreciated!! Thanks.
Klipsch RF-82II Floors
Klipsch RC-62II Center
Klipsch RS-42II Surrounds
SVS PB12-NSD Sub
Marantz SR7010 Receiver
2016 Vizio P65-C1
RMZguy151 is offline
post #2 of 5 Old 01-13-2013, 04:01 PM - Thread Starter
RMZguy151's Avatar
I think I may have figured it out!
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #3 of 5 Old 01-13-2013, 04:10 PM
doug527's Avatar
and it was?
doug527 is offline
post #4 of 5 Old 01-13-2013, 04:18 PM - Thread Starter
RMZguy151's Avatar
I was messing around with the receiver video settings and found the i/p scaler and set it to HDMI instead of off. Then made some adjustments to the resolution, that did it. I am so happy it was something that simple.
SVS PB12-NSD Sub
2016 Vizio P65-C1
post #5 of 5 Old 01-20-2013, 02:39 PM
doug527's Avatar
good to hear
doug527 is offline
