Need help understanding my Yamaha's LFE setting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-14-2013, 10:09 PM - Thread Starter
likemovies's Avatar
Quoted: 28 Post(s)
Using HTR-5930. It has the LFE setting for my sub. But, it starts at zero and then goes left to negative numbers. I read the manual but it does not tell me what going negative means. I just keep it at zero but I don't know why.
I don't have any sort of crossover settings for the traditional 80hz. There's nothing to set. Just speaker size. I didn't know if maybe this LFE setting area had something to do with it.
Samsung 51" PN51E450A, Pioneer VSX-918V, Polk Tsi300, Polk CS 2 series ii center, Energy S10.3.
likemovies is offline
post #2 of 5 Old 01-14-2013, 10:14 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
It's just a way of reducing the level of the sub's output. It just goes to lower levels instead of both +/- directions. You sure there's not another setting to do both plus/minus trim adjustments?
lovinthehd is offline
post #3 of 5 Old 01-14-2013, 10:37 PM - Thread Starter
likemovies's Avatar
Quoted: 28 Post(s)
I'll look again, maybe. But if I'm at zero and say I move it -5. What does that mean? What if I move it +5?
I read Yamaha hardcodes their receivers, or at least mine, at 90Hz. Does this LFE setting make it 95 (+5) one way and 85 (-5) another?
post #4 of 5 Old 01-14-2013, 10:54 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Those numbers are in reference to gain (volume) control relative to the other channels. If the sub is too high you would back it down (-2 or -4 etc) - if it wasn't loud enough you'd increase the gain to 0 or +1 etc. You can also do this with the other channels to balance out the volume levels. It does nothing to control the crossover. If its hardwired as you say to 90hz then the crossover will remain 90hz. The sub kicks in at and below 90hz and the other speakers kick in at 90hz and above.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 5 Old 01-15-2013, 07:38 PM
lovinthehd's Avatar
Liked: 4775
I thought you were saying your sub adjustment only went from 0 down to -5. This is usually a dB measurement, from the starting point of 0.
