Decision on entry level receiver - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2013, 10:46 PM - Thread Starter
nitlsu's Avatar
I am trying to decide on a sub-$300 entry level receiver. The candidates I am considering are,
Yamaha RX-V471BL : It's last year's model but the price seem right and the features are all there except AirPlay (I can just buy an AppleTV for 100 bucks).
Pioneer VSX-1022 : It's 7.1 with more HDMI in compared to the Yamaha plus builtin AirPlay, Pandora etc. But reading the reviews on NewEgg it seem fraught with problems. Multiple people report failure within a month.
Harman Kardon AVR 1700: Only 5.1. The reviews seem decent but many threads here and other sites suggesting HK is past it's prime and they are a step behind in features etc.
Yamaha RX-V373 : Current year model but more expensive than the RX-471.
Any recommendations? Or if there's anything better out there that I have missed from any of the other manufacturers? Your suggestions would be most appreciated. My requirements are reliability and best bang for the buck in terms of features.
nitlsu is offline
Old 01-16-2013, 12:08 AM
All-Or-Nothing's Avatar
I'm in the same boat as you. I'm leaning towards the RX-V373. Price is good and Yamaha reliability is even better.
All-Or-Nothing is offline
Old 01-16-2013, 03:22 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
The Denon 1613 (5.1) includes Airplay as well as Audyssey MultEQ which can EQ the subwoofer, which most of the above are unable to do. Give AV Science sales or Electronics Expo a "call" for their best price. Review post #2 of the Denon AVR-XX13 Owner's thread linked in my sig for a comparison of features with the other XX13 models.
jdsmoothie is offline
Old 01-16-2013, 06:55 AM - Thread Starter
nitlsu's Avatar
Thanks for the tip...I will try calling them to see what kind of price I can get. I would have liked Denon but I always thought they were beyond my price range for a comparable feature set.
nitlsu is offline
Old 01-16-2013, 10:22 AM
jkaetz's Avatar
Only thing I would say is don't worry about a model year difference unless the new model year adds a specific make or break feature for you.
jkaetz is offline
Old 01-16-2013, 10:26 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
+1 on the 1613 - got it new on Black Friday for under $300... killer deal for a great entry level AVR. Does everything I want it to do and after I ran Audyssey it made my speakers sound much better.
accessoriesforless had the 1613 refurb not too long ago - not sure if they still do, may want to check there as well.
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
Old 01-16-2013, 10:47 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The Yamaha and Pioneer receivers have really gone downhill in the sound quality area IMO. I personally would never recommend one to a friend.
I think you would be well advised to consider an Onlyo TX-NR515, which I find superior in most respects.
The Denon is also good.
commsysman is offline
Old 01-25-2013, 02:20 PM - Thread Starter
nitlsu's Avatar
Thanks for all the advice. I think I am much closer to a decision and of course much wiser smile.gif
I was going to go with the Denon 1613 but today I went to BB and noticed they had the Denon AVR-3312CI for $450+tax (open box, missing remote and microphone). So I am in a bit of a quandary now....obviously the 3312CI is a much better receiver for just a 100+ bucks more. But with a missing remote/microphone I am not sure.
Any advice? Thanks and much appreciated.
nitlsu is offline
Old 01-25-2013, 02:23 PM
wronganswer's Avatar
Marantz 1403
wronganswer is offline
Old 01-25-2013, 07:10 PM
jdsmoothie's Avatar
Liked: 5508
You can buy a DM-A409 mic for about $25 and the remote will cost about $50 although you would be much better served with a $50 Harmony remote instead. Although for the roughly additional $200 you'll pay to upgrade to the 3312CI, you may also want to consider sticking with the 1613 and putting that money instead into better quality speakers.
Old 01-25-2013, 07:16 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
Honestly... Onkyo or Denon with a heavy lean twoards Denon. If you can step up to the 1713 Model for better Room correction I would do it.
1713 is a sweat spot for Denon 5.1. Look for the best level of room correction you can afford.
If you don't believe me...buy a Yamaha...and the Denon 1713... Compare the two side by side and return one or both to Best buy. I bet donkey's to dollars you like the Denon better.
Newbie01 is offline
Old 01-25-2013, 10:34 PM
bgstewar's Avatar
Quoted: 30 Post(s)
Here's an interesting comparison between the Denon 1612 and Yamaha 471. Said the Yamaha was better.
I'm in the same boat as you. And with the recent sale of the HK AVR 1700 at $199 (currently at Amazon, OOS but can still order it), that really muddles the picture because of how cheap it is and the feature set you get (AirPlay, discrete amps per channel, network, etc.).
It's funny - I've been researching for weeks on so many forums. Most people say Yamaha is the best for sound quality, then someone here says they're terrible. Someone here recommended Onkyo, where everywhere else I've read said they're terrible unreliable and have HDMI issues all the time.
I guess it comes down to who is giving you advice. I would narrow it down to price and features and make your decision. Keep in mind you'll have this piece of equipment most likely for a long time. I'm sure no matter what you choose, you won't regret it. You may regret how much time you put in to comparing all the entry level models. I know I'm starting to! tongue.gif
bgstewar is offline
Old 01-26-2013, 04:15 AM
jdsmoothie's Avatar
Liked: 5508
Correct. It all comes down to personal preference as we all have different speakers and different room environments as well as different ears. In the poster's opinion it was "slightly" better although also note the poster does not compare the YPAO (Yamaha) vs. Audyssey (Denon) which is likely to make the difference as the YPAO cannot EQ the subwoofer.
Old 01-26-2013, 05:33 AM
msocccerw's Avatar
Should I get the demon 1613 or 1712 or any other suggestions for around $300. For my set-up, Epson 3010, ps3, direct tv, pioneer sp-bs21-lr, sp-c21, sw-8 speakers. Thanks everyone.
msocccerw is offline
Old 01-26-2013, 07:45 AM
jdsmoothie's Avatar
Liked: 5508
Depends on which you prefer ..... better audio quality (1712) or networking (1613).
Old 01-26-2013, 07:51 AM
msocccerw's Avatar
I guess audio, do you think that setup is fine or you think a different speaker setup for a 22'x12' room, enough bass?
Yamaha Rx V471bl 5 1 Channel Av Receiver , Pioneer Vsx 1022 K 560w 7 Channel A V Receiver , Harman Kardon Avr 1700 5 1 Av Receiver , Yamaha Rx V373 5 1 Channel Av Receiver , Denon Avr 1613 Receiver , Onkyo Tx Nr515 , Denon Avr3312ci Receiver , Marantz Nr1403 Slim Line Av Receiver , Epson Active Shutter 3d Glasses For Powerlite Home Cinema 3010 3010e 5010 5010e And Pro Cinema 6010
