DCX 2496, behringer ep2500 and polk RTI12's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-16-2013, 11:18 PM - Thread Starter
pjoseph24's Avatar
I plan to remove the crossovers in the speakers and wire the 3 7” drivers in series to get 8 ohms. I am going to connect the pre outs on my Onkyo 709 to the DCX 2496 and from there to the behringer ep2500. I wanted to ask if I should just use the crossover points listed in the manual I believe its at 120hz? Are there any other settings I should set up on the DCX for this setup?
I am not going to touch the mids or tweeters for now, they will be stay connected using my Onkyo 709
I also have a marantz sr4001 that I am not using that I may use to power the 7” drivers as well since eventually I will need to use the ep2500 for my sub.
pjoseph24 is offline
Polk Audio Speakers Rti 12
