Recommend an AVR with Pre-Outs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-17-2013, 01:24 PM - Thread Starter
psuKinger's Avatar
Quoted: 692 Post(s)
Liked: 188
I currently use an Onkyo TX-SR606, which has no pre-outs (I'm looking to add an Amp to power my Fronts and maybe my Center) and no ability to add Front Highs.
I currently am set up for 5.1, but I want the flexibility to maybe go to 7.1 in the future.
I currently use a PS3 for Blu Ray, so being able to decode TrueHD/DTS-HD-MA isn't necessary, as long as it can handle Linear PCM.
And as I indicated above, although I don't currently use Front High's, I'd like to potentially give it a try in the future, so I'm looking for both that connection and an ability to run Pro Logic IIz.
I'd like to be have at least 100 Watts RMS available (at 8 ohm), for the remaining Rear Channels, which I intend to power out of the AVR.
Anybody care to recommend an AVR (or two) that will do discrete 7.1, 100 Watts RMS, Pro Logic IIz, and have Pre-Outs for an external amp? I believe the Onkyo TX-NR709 meets my needs, but wondering if anybody else has any suggestions, particularly outside the Onkyo family (which I'm more familiar with) that I should be looking at...
psuKinger is online now
post #2 of 6 Old 01-17-2013, 02:03 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
The HK AVR3600 and about to be released 3700 have 7.1 pre-outs. Both have Harman's Logic 7, which imo, is far better than DPLii or dts-neo6. The 3700 also has Airplay, the 3600 does not. The 3600 has 80wpc the 3700 has 125wpc.
psuKinger likes this.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 6 Old 01-18-2013, 07:42 AM - Thread Starter
psuKinger's Avatar
Quoted: 692 Post(s)
Liked: 188
Thanks for the recommendation.
Online prices that I found show the AVR3600 at $899. Amazon has the Onkyo 709 and 809 for $529 and $659, respectively. Any reason you would speak to, other than the "Logic 7" you've already mentioned, for choosing the HK over either Onkyo?
I also found the Pioneer Elite SC-61 for $750... and, at first glance, I think it might meet my needs as well.
post #4 of 6 Old 01-18-2013, 08:02 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Actually the 3600 is going for less than you quote. Forget where I saw them. The $899 is MORE than I just paid for one here in Ecuador.
imo, HK AVRs, amps sound superior to Onkyo. And are much more reliable also.
4DHD is offline
post #5 of 6 Old 01-18-2013, 09:37 AM
Katie Meadow's Avatar
Katie Meadow is offline
post #6 of 6 Old 01-23-2013, 09:42 AM - Thread Starter
psuKinger's Avatar
Quoted: 692 Post(s)
Liked: 188
Wanted to bump this just once and see if anyone else has any other recommendations they'd share.
