9.2 Home Theater Set Up on a Budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-17-2013, 08:03 PM - Thread Starter
Knight Operator's Avatar
Hey everyone, first post and I want to quickly say thanks to all the members here for providing a wealth of information to the internet on everything to do with AV. Really a superb forum and im glad to be apart of it!
Q1:
Anyways, Heres my inquiry. Lets say you have want a 9.2 set up, you've bought the speakers. The goal is to get a receiver that does 9.2, DolbyTrueHD, DTS HD, audyssey (murdered that spelling probably I know) THX certified, & 2K/4K/3D pass through. Also, to amp the speakers (not the subs) (could also be an internal amp in the receiver) to somewhere in the vicinity of 150-250 watts @ 8ohms/channel.
What is the best way to go about this as cheaply as possible. What products & price.
The entire speaker set up costs approx $2500 (including subs)
The setup i was considering was:
BIC AMERICA ACOUSTECH series
FL-FR: PL-89
CTR: PL-28
SURROUNDS: PL-66 (4)
HEIGHTS: PL-28 0r PL26 (2)
SUBS: PL-200 (2) & possible 1 or 2 more that can reach lower bass extension <15Hz
the speakers can be amped up to 250Watts RMS
8 Ohm and very efficient @98/96db @ 1 watt @ 1 meter
Overall positive ratings and feedback. Good price/quality ratio. 8yrs warranty on woofers, 2yrs on amps (subs only)
Nothing is set in stone as of yet.
Point me in the right direction. GO!
Knight Operator is offline
post #2 of 10 Old 01-18-2013, 02:34 PM - Thread Starter
Nothing? no suggestions?
post #3 of 10 Old 01-18-2013, 03:58 PM
Darfyddi's Avatar
I don't really know anything about this sort of stuff but I am saving up for an Onky TX-NR3009 that I think does all of that but I also think that Yamaha and Denon do something similar too. Onkyo has a good website to tell you the tech-specs but I find the various online reviews best to actually explain what these beautiful beats can do.
Hope that helps you a bit.
Darfyddi is offline
post #4 of 10 Old 01-18-2013, 04:02 PM
zgeneral's Avatar
Quoted: 874 Post(s)
Liked: 213
You're on a budget, why would you want an 11 speaker solution? Go find the best 5.1 system that fits in your budget. You won't notice the difference. Also, I'm not really sure what "on a budget" means given that you're looking at a $1,400 receiver. If you have that much money just for a receiver, why not wait a bit until you're not on a budget and pay some professionals to do things for you.
Alternatively, unless you have a mammoth room, get yourself a reasonable low-mid range Denon and pair it with some nice used speakers from Craigslist.
FYI, people on a budget don't spend $5k for a surround sound setup. They buy $500 Home theatre in a box setups.
"don't get caught up in the number of speakers in a surround system to the detriment of the core 5.1 system, including speakers, processor amps and source components."
http://hometheaterreview.com/with-receivers-packing-92-performance---how-many-channels-of-surround-is-too-many/?page=2
cchunter likes this.
zgeneral is offline
post #5 of 10 Old 01-24-2013, 07:20 PM - Thread Starter
Ive been puting together surround sound systems since i was 12, i would really have to want to waist money to pay someone to do something as simple as put together a home theater, nor is that option cost effective. A budget can be any sum of money, whether were talking hundreds of dollars to billions- both are budgets. My parameters were how cheaply can i have a receiver with 9.2, DolbyTrueHD, DTS HD, audyssey, THX certified, & 2K/4K/3D pass through and given the price for the speakers, im obviously not looking for a $10,000 receiver. How cheaply can i get y with x,x,x,x,x,x features- pretty straight forward. I already own a decent 5.1 (2 subs), and 7.1 (with 3 subs), time to do a dedicated room.
Thanks Darfiddi, you got the idea, any other suggestions?
post #6 of 10 Old 01-24-2013, 07:55 PM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
For your oddly specific requirements, I believe only the Onkyo 3010/5010 qualify among current models. If you can still find last year's models (1009/3009/5009), they would also qualify. I personally can't recommend Onkyo, however, given their numerous quality issues (I have had two separate Onkyos with HDMI board failure and there are numerous Onkyo failure threads on this forum).
If you don't care about THX certification (it's little more than marketing), then I think your best bet is either the Denon 4311 (around $1500) or the Yamaha 3010 (also around $1500). I know Yamaha uses YPAO, but I have had positive results with both YPAO and the vaunted Audyssey XT32. Both EQ two subs, which is one of the features of XT32 that many tout.
tsaville is offline
post #7 of 10 Old 01-24-2013, 09:03 PM - Thread Starter
post #8 of 10 Old 01-25-2013, 04:03 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
I'd start with a Denon AVR-4311 ( $1150 refurbished + $150 for 5-year warranty from A4L ) or Onkyo TX-NR3009 ( $1250 refurb + $150 @ A4L ). NONE of these receivers are 11.x receivers but they are capable of it by adding an external amp. An Emotiva 5-channel amp will cost $900 and take about 70-80% of the power load off the receiver running in 11.x.
The BIC speakers you chose should be fine with any of these receivers but, like others have said, you can take the entire $2500 and invest in a better 7.2 setup and build up from there. Setting your room up with the goal of expanding it later is what most folks do. It is what I did. The 9.2 receiver can be your core and also plan your power outlets with the idea of adding an external amp. Plan out your speaker layout with the idea of getting a core 5.2 system now and then doing the front to surround speaker shuffle down the road. 90% of ALL content out there is STILL 5.1, so all you'd be doing with those is matrixing the additional speakers 90% of the time. There are only a couple of discs out there now that are matrixed in the studio for DTS Neo:X 11.x, so I won't be really using MY 11.2 setup until I receive Expendables 2 in a few days.
I started my REAL effort with an assortment of JBL speakers ( L7 plus matching center ) along with EoSone surrounds which was about $2500 for a 5.0 setup. I added the Definitive Technology BP7000SC and C/L/R 3000 a few years later at a cost of around $6500. The DefTech towers, with their built-in 1800 watt powered subs, give plenty of low end, so I don't have the desire to have a stand-alone sub. I moved the JBL to the back and sold off the JBL center and went to a 7.2 setup and upgraded the receiver to a Denon AVR-5308ci for $5000. I added two DefTech SM55 and two DefTech UIW BPZ/A for about $1100 to make up the current 11.2 setup. At the same time I added an Emotiva XPR-5 amplifier, 400 watts x 5, to power the core 5 speakers at a cost of $1532. So. All of the money I put into my current setup was over about 15 years and the only thing I really sold off was the JBL center channel. I still have my 4 original speakers from 1997 and 2001 but I'm not counting the POS Sony HTiB I had before that. My first real 5.1 setup was with a Sony STR-DE805, then Denon AVR-5600, AVR-5803, and current AVR-5308ci. So. I've upgraded receivers about every 5 years.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #9 of 10 Old 02-07-2013, 11:02 AM
Cincinnati Dan's Avatar
I'm also looking at 9.2 receivers, and think the Pioneer Elite SC-65 is what I want. I'm not sure what the difference is between the SC-65 and the non-Elite SCC-1522-K. Does anyone know the difference?
Cincinnati Dan is offline
post #10 of 10 Old 02-07-2013, 02:03 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2902
For a 9.2 set-up, I would start with the Denon AVR-4311, which has the features you mentioned (including latest version of Audyssey and support for 2 subs). With 9 built in amplifiers, no need to buy external amps to power the height speakers:
http://www.accessories4less.com/make-a-store/item/DENAVR4311CI/DENON-AVR-4311CI-9.2-Channel-Network-Home-Theater-Receiver/1.html
Since the low frequencies are going to be handled by subwoofers, I wouldn't get those Bic towers because there's no need for large front speakers to cover the bass range that's already covered by the subs. Instead I would get 9 of these Bic bookshelf speakers:
http://amzn.com/B002ISTP8K
That will give better consistency as sounds move around the room; certainly better than having a centre speaker that is different from the front speakers which are different than the surround speakers which are different from the height speakers.
Finally, for subs, would get a pair of these Bic models:
http://amzn.com/B0015A8Y5M
To re-cap:
$1150 (Denon 4311)
$150 (five year warranty)
$900 (nine Bic FH-65B)
$376 (two Bic F12 subs)
$2576 Total
Pretty close to your budget.
Sanjay
sdurani is offline
