Will my speakers get blown - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-17-2013, 10:11 PM - Thread Starter
mijotter's Avatar
Liked: 59
I'm looking at the Onkyo 809, it says 135 watts per channel however my sides and rears are only rated to 100 watts. What does this mean? Will they get blown or will the receiver downscale at all? Thanks.
mijotter is offline
post #2 of 8 Old 01-18-2013, 01:11 AM
GaryWA's Avatar
Quoted: 16 Post(s)
You will be totally fine. You won't be giving them 135 RMS which is the continuous output.
Also, keep in mind that it is almost always better to give speakers more power than less power.
RPGMasta likes this.
GaryWA is offline
post #3 of 8 Old 01-18-2013, 01:17 AM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
You only get 135 wpc when you are only using 2 channels. You will be using a lot less when you use 5.1, 7.1 or 7.2 set up.
GusGus748s is offline
post #4 of 8 Old 01-18-2013, 01:08 PM - Thread Starter
mijotter's Avatar
Liked: 59
What would be the watts per speaker for a 7.1 setup then?
mijotter is offline
post #5 of 8 Old 01-18-2013, 01:51 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
I guarantee you that if your speakers were rated at 135 watts, and you were bound and determined to do so, you could probably blow them with a 135 wpc receiver.
Speaker watts aren't hard and fast like house fuses.
100 watt speakers + common sense + 135 wpc receiver = happiness
100 watt speakers + intoxicated and feeling wild + 135 wpc receiver = blown speakers.
arnyk is offline
post #6 of 8 Old 01-19-2013, 01:44 PM - Thread Starter
mijotter's Avatar
Liked: 59
LoL ok gotcha. Plus I just realized that my fronts and center are rated at 250 and 150 watts so I shouldn't have any issues. Plus my Sub will be pre amped as well. I'm a total noob when it comes to audio like this, would there be a way to calibrate the center and fronts taking more watts than the surrounds, perhaps stealing some watts from them?
mijotter is offline
post #7 of 8 Old 01-19-2013, 02:52 PM
M Code's Avatar
Quoted: 719 Post(s)
Liked: 423
Key point is not to drive the amplifier into clipping distortion..
As long as its output is clean a good loudspeaker will handle it with no problem..
M Code is offline
post #8 of 8 Old 01-19-2013, 04:03 PM
Theresa's Avatar
Liked: 51
Thermal overload from driving a loudspeaker too loud for too long probably damages speakers more frequently than clipping does.
Theresa is offline
