Please delete - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-19-2013, 08:05 AM - Thread Starter
hevnbnd's Avatar
Got it.
hevnbnd is offline
post #2 of 2 Old 01-19-2013, 11:59 AM
Socketman's Avatar
Quoted: 163 Post(s)
Liked: 170
If you are referring to the STR DA5800 ES , you would connect via RCA cables the pre-outs from the Sony to the appropriate inputs of your DTA 70.1 . You would then connect your speaker wires to the 70.1 . Also you would select the input on the 70.1 by moving the switch on the rear of each input. The sony can also trigger the DTA 70.1 to power on and off.
Socketman is offline
