Good receiver with Zone 2 pre-outs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-19-2013, 10:02 AM - Thread Starter
Jeffy76's Avatar
I'm looking for a quality receiver with Zone 2 pre-outs. I originally picked up the Denon 1913 not realizing that it did not fit my needs. If i'm researching correctly, the first Denon model with Zone 2 pre-outs is the 2313. I really like that model, but the price is a little higher than i want to pay. Can anyone recommend something that will work for me?
Jeffy76 is offline
post #2 of 10 Old 01-19-2013, 02:15 PM
jdsmoothie's Avatar
Quoted: 12082 Post(s)
Liked: 5502
The 1713 also has Zone 2 pre-outs.
jdsmoothie is offline
post #3 of 10 Old 01-19-2013, 02:56 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Most mid-range AVRs and up have Zone II pre-outs..
However note that only sources connected (plus built in AM/FM tuner) via analog R/L cables will work...
Therefore run an extra set of cables for each, and things should be fine..
M Code is online now
post #4 of 10 Old 01-19-2013, 07:05 PM - Thread Starter
Jeffy76's Avatar
Is that right???
Jeffy76 is offline
post #5 of 10 Old 01-19-2013, 08:27 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Originally Posted by Jeffy76 View Post
Is that right???
Yup...
The 1713 has Pre-Outs for Zone II, these have to be connected to an external stereo amplifier. As the 1713 is only a 5.1 with (5) channels of on-board amplification.
post #6 of 10 Old 01-20-2013, 04:32 AM
jdsmoothie's Avatar
Liked: 5502
Is that right???
Also, if you refer to post #2 in the Denon AVR-XX13 Owner's thread linked in my sig, you can view a comparison of all the various XX13 models.
post #7 of 10 Old 01-24-2013, 01:48 PM - Thread Starter
Jeffy76's Avatar
Awesome, thanks.
Jeffy76 is offline
post #8 of 10 Old 01-24-2013, 02:35 PM
npgatech's Avatar
Keep in mind that the Zone 2 preouts will only pass the analog input signals. No HDMI or Digital inputs. So, you won't be able use your receiver as a DAC unless you go with the 3313CI or bigger I believe.
npgatech is offline
post #9 of 10 Old 01-25-2013, 08:02 PM
jdsmoothie's Avatar
Liked: 5502
Actually that feature was also removed from the 3313CI as well, although the 3313CI does have the Zone 2 (HDMI) jack that can cnonect to either a TV or 2nd AVR.
post #10 of 10 Old 01-25-2013, 11:25 PM - Thread Starter
Jeffy76's Avatar
I am aware, thanks. I plan on connecting RCA's in addition to my HDMI's.
Jeffy76 is offline
