Receiver not delivering enough power? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-19-2013, 09:47 PM - Thread Starter
guzami77's Avatar
I have Boston VR3 speakers:
http://gadgets.softpedia.com/gadgets/Television-and-music/The-Boston-Acoustics-VR3-Loudspeakers-5302.html
and Pioneer VSX-1120-K receiver
http://reviews.cnet.com/av-receivers/pioneer-vsx-1120-k/4507-6466_7-33983135.html
My buddies are trying to tell me the sound isnt high quality because of the receiver.. and want me to upgrade.
Opinions?
guzami77 is offline
post #2 of 4 Old 01-19-2013, 10:39 PM
gregzoll's Avatar
Liked: 33
Tell your buddies, that if they wish, they can spend their own hard earned money to buy you a better system.
gregzoll is offline
post #3 of 4 Old 01-20-2013, 11:57 AM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
Opinions?
So your friends are saying that they don't like the sound of your system. The important thing is, do you like the way it sounds? What gear are they using?
You don't mention how many speakers you have hooked up. Are you using just the two towers in stereo?
The receiver is putting out a minimum of 110 watts x7. The speakers have a 93 DB sensitivity rating, which means they don't need much power to get loud.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #4 of 4 Old 01-20-2013, 03:04 PM
SRussell's Avatar
Quoted: 14 Post(s)
I have this receiver and think it sounds fine. Have you run MCACC? I am running NHT speakers that are not exactly the most efficient and my system gets plenty loud. You might want to look at the official MCACC thread to optimize your results. You may also look at speaker positioning. I wasn't completely thrilled with my first MCACC experience with this receiver and after adjusting my speaker positions and going through the MCACC thread it sounds much better.
SRussell is offline
