*DONT KNOW HOW TO USE DENON AVR-391 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-20-2013, 07:53 AM - Thread Starter
thewitebook's Avatar
Hello, please i don't know how to use this technology. How should I setup properly to play tv frequencies and dvd/cd also from apple tv netflx)
I am using 2 large fronts a center and a sub.
So many setting in the manual and no one in the store helps me.
thewitebook is offline
post #2 of 2 Old 01-20-2013, 02:37 PM
jdsmoothie's Avatar
Quoted: 14565 Post(s)
Liked: 6916
Had you gone one model higher (ie. 591), you could have used the Audyssey MultEQ speaker/sub auto EQ program, but as it stands, the 391 has no such feature. So simply connect your sources to the AVR and select them on the remote.
jdsmoothie is online now
