Yamaha RX-V667 Bi-Amp Issues - Check SP Wires - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-20-2013, 09:30 AM - Thread Starter
Ason12's Avatar
Hey all,
I recently decided to Bi-Amp my front speakers with my Yamaha RX-V667. I've hooked up everything with banana plugs to the second posts on my fronts and into the correct ports on my receiver. However, now when I try setting it up or running YPAO or anything. The receiver shuts off and when I turn it back on it says Check Speaker Wires. I'm not sure what the issue could be it only happens when I set it to 5 Ch Bi-Amp, not when it's on 7 Ch.
What would you all recommend I do? I'd really like to Bi-Amp the speakers, even though I know it won't have a ton of extra effect.
Thanks!!
Ason12 is offline
post #2 of 3 Old 01-20-2013, 09:50 AM
grasshoppers's Avatar
Quoted: 859 Post(s)
Liked: 555
Are the speakers connected to the surround back/bi-amp terminals??
If they are connected to the "B" terminals you have done it incorrectly.
Also,you can't do 7.1 and bi-amp too.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #3 of 3 Old 01-20-2013, 06:55 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
Did you remove the straps between the top and bottom terminals on your speakers?
jdcrox is offline
Yamaha Rx V667 Receiver
