Novice needs help pairing new AVR with speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-21-2013, 07:25 PM - Thread Starter
tommyncal's Avatar
I posted over in the speaker forum with not a whole lot of help with the pairing. Right now I'm leaning towards the Wharfedale Diamond 10.2 L/R speakers ( 6 ohms / 86dB ). I have read, somewhere in here, that Wharfedale speakers need more power. I have no Idea how much, especially if I add a center and sub later on.
I'm considering the Denon 1713 or 2113ci receiver. All I'll ever want in my entertainment room is 5:1. However, outside in a large patio I would like a second zone. I'm assuming, from how I understood it, the 1713 gives me the zone 2 but would need another amp and volume controller? And with the 2113ci I could power and control the volume to the same zone 2 from the same receiver? Is this correct? About $200 difference, but I thought the extra amp and controller would probably cost at least that much, correct?
Being a total novice, I'm not set on any particular brand, but from what I've read, it seems Audyssey would be a great help, to me, setting up the speakers. Also, would like to control the system with an ipad. So, would either of those receivers power the wharfedales 10.2, a center, and a sub ( added later on )?
tommyncal is offline
post #2 of 3 Old 01-21-2013, 09:48 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3097
The Denon receivers are designed to power 6-16 ohm speakers. The Wharfdales are moderately efficient. The most cost-effective solution would be to get the 2113 or similar receiver. I think the 2113 would be a good purchase as you will get the 2 powered zones, networking and most importantly Audyssey MultEQ XT.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 3 Old 01-22-2013, 12:13 AM - Thread Starter
tommyncal's Avatar
Thanks for the reply. Does the 'moderately efficient' description of the Wharfedales mean should should be paired with a much more powerful receiver. I would think that moderately priced bookshelf speakers ($350/pr) shouldn't need a very costly (very powerful) receiver. I'm just trying to understand all of this. I don't want to get them if I will be under powering them or not being able to get the full potential out of them. Thanks again.
