Yamaha RX-773 remote control setup for Philips BDP5200/12 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-22-2013, 02:07 PM - Thread Starter
jjabba's Avatar
Connected to my Yamaha RX-773 I have (among other devices) a Philips BDP 5200/12 blu ray player.
The RX-773 remote control have the ability to control other devices so i naturally tried setting up the remote using the remote control identifiyer code listed under Philips in the "Blu-ray Disc" section of the Yamaha IR code manual (code 2510).
However, the remote control code listed doesn't work so I went online and googled for the actual hex values and found this post:
http://www.supportforum.philips.com/en/showthread.php?4960-Discrete-IR-code-for-Blu-ray-players-and-Home-Cinema-Sound-system
But unfortunately I have not found a similar for the yamaha remote presets so I'm at a dead end...
Since the Philips BDP5200/12 is a quite common blu ray player i'm looking for someone who has found a working setup code in the Yamaha list for it.
jjabba is offline
post #2 of 3 Old 04-06-2013, 04:36 AM
shadow_zero's Avatar
I recently have a Yamaha RX-V1071 and am looking for a remote control code for my Philips BDP8000.
These still have not surfaced?
shadow_zero is offline
post #3 of 3 Old 04-06-2013, 04:47 AM - Thread Starter
jjabba's Avatar
I 'solved' my problem by using the RX-773 remote's programming functionality. Effectively teaching it all the buttons on my Philips BDP 5200/12 remote one by one.
But I have not heard nor found any listing of the Discrete IR codes of the Yamaha remote yet.
If you do, please post it in this thread.
jjabba is offline
