Broken Receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-23-2013, 12:46 PM - Thread Starter
truwrxtacy's Avatar
Hey guys i have a Onkyo HT R960 receiver I got as part of a Home Theater in a box the Onkyo 7.1 THX system. I have a feeling its going bad but i'm not 100% sure how to trouble shoot it. Currently I have a PS3 and a Apple TV. When i try to play my PS3, it takes the receiver about 2-3 minutes to pick up my PS3, i would have to constantly switch it from DVD to AUX back to DVD (its currently plugged into the DVD HDMI input)
I have the apple TV plugged into the SAT HDMI, but when i use turn on the Apple TV, the receiver picks up the apple TV right away. So is my receiver going bad? i'm pretty sure its not my PS3 as i have 2 ps3 and i tried both of them and have the same results. I even plugged my ps3 directly into my TV and it picks up right away, only takes awhile when its going through my receiver. I have tried different HDMI inputs/outputs and all the same results. Any advice would be great.
thanks
truwrxtacy is offline
post #2 of 5 Old 01-23-2013, 01:27 PM
afrogt's Avatar
Quoted: 1066 Post(s)
Liked: 773
Possibly going bad. Onkyo has a been having problems with HDMI boards dying on several receivers.
Might want to look at replacing your receiver.
Afro GT
afrogt is online now
post #3 of 5 Old 01-23-2013, 01:46 PM - Thread Starter
truwrxtacy's Avatar
aww crap, i was hoping you wouldn't say that. is there a reason why it picks up my Apple TV with no issues but has issues with the PS3? even if i tested them both through the same port?
post #4 of 5 Old 01-23-2013, 05:30 PM
rocky1's Avatar
Can u try changing the hdmi cable of the ps3 ?
rocky1 is offline
post #5 of 5 Old 01-23-2013, 06:24 PM - Thread Starter
truwrxtacy's Avatar
yes i tried different HDMI cable also. i bascially swapped everything that worked (cable/hdmi port) from the apple tv which works great to the PS3, still takes about 2-3 min to pick it up
