Need help with NAD amps....... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-23-2013, 12:47 PM - Thread Starter
harleymag's Avatar
I have 2 NAD 218-THX Amps, C-160 Pre Amp, 2 Velodybne SPL 12 inch subs and two PSB Goldi speakers. I have the amps bridged and sounds awesome to me. I hear using the XLR imputs might be better, but no XLR imputs on back of pre amp. Anyways, I've always wandered if possibly bi-amping or bi-wiring would achieve better sound. Would appreciate some input from someone who actually knows something.......thanks.
harleymag is offline
post #2 of 3 Old 01-24-2013, 10:42 AM
gferrell's Avatar
Quoted: 27 Post(s)
Those are very good amps, Bi-wire does nothing but you should try bi-amping those speakers rather than bridging the amps. I think you will like it.
Wishing I could post in the Ultra Hi-End HT Gear ($20,000+)
gferrell is offline
post #3 of 3 Old 01-24-2013, 10:58 AM - Thread Starter
harleymag's Avatar
Thanks for the reply. Amp is 225 wpc........but when bridged, gives me 780 watts. Was told when I bought them I was better off with more power.........but just curious as to what might be a better way to go.
