Can i connect my cable set top box to Yamaha HTR-7065 via component cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-23-2013, 11:48 PM - Thread Starter
Mayoor Singal's Avatar
Hi All,
I just bought a new Yamaha HTR-7065. I have an apple TV, PS3, a PC and a Cisco Cable Set Top box in my setup. All else works great except the cable.
I read the manual and set my AV2 option such that audio for it comes from AV6 (component audio). In other words, the R,G,B of the component cable from set top box goes into AV2 and Red and White of component cable from set top box goes into AV6. I matched the On Screen settings for AV2 to reflect the same.
The above isnt giving any audio or video although i am certain the cable set top box is switched on.
Any help that any one can provide on this will be highly appreciated
-Mayoor
Mayoor Singal is offline
post #2 of 7 Old 01-24-2013, 09:37 AM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1301
Try using the optical audio out from the cable box.
Why not use the HDMI from the cable box though?
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 7 Old 01-24-2013, 11:25 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
you probably have to assign the component video to a certain input and you also need to have the HDMI conversion on if it isn't.
i'm guessing you have a HDMI cable connected to your tv?
Does you cable box not have HDMI?
Afro GT
afrogt is offline
post #4 of 7 Old 01-24-2013, 12:39 PM - Thread Starter
The cable box does have the HDMI capability and it will work, but being new to this, I am trying to wrap my head around, why it won't work with Component cable.
my component video is connected to AV2. Not sure what or how to do HDMI conversion.
Thanks for your reply
post #5 of 7 Old 01-24-2013, 12:40 PM - Thread Starter
Mayoor
post #6 of 7 Old 01-24-2013, 12:41 PM - Thread Starter
Even with optical cable from cable box, won't the video issue still persist?
Mayoor
post #7 of 7 Old 08-24-2014, 06:46 PM
Liked: 0
I had a similar problem just figured it out
I was trying to set up a Wii to the HTR 7065 which has only one of the HDMI outs used for a projector. I followed the manual instructions like you did (pages 29-30) but it wasn't until I did a document search for "conver" (conversion, converted, etc) and found, on page 123, the video conversion table which shows that the receiver will convert 480i to HDMI but NOT 480p. I had to take the Wii to another TV to change that in the Wii setup menu, then plug it back into the Yamaha receiver and voila! It works.
Hope that helps.
Name:	Yamaha video conversion table.jpg
gowens is offline
Yamaha Htr 7065
