TX-NR515 is a no go. Alternatives? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-24-2013, 05:06 PM - Thread Starter
TK423's Avatar
Beginning to set up my first non-HTIB set up. My Polk New Monitor 65Ts are on the way. (Planning to work up to 5.1 gradually as budget allows.)
I was pretty deadset on the Onkyo TX-NR515 as a receiver due to several recommendations but after further research online it seems that line (515, 615 and one other, I believe) were plagued by some pretty bad HDMI issues and a high fail right.
I'd rather not take the unnecessary risk of buying a flaky product so I'm trying to find a good budget alternative, preferably an Onkyo. It seems like you get more bang for your buck with them.
My budget is around $300. I'd rather not go much over but if a little bit will make a world of difference, it's doable.
I've been interested in the TX-NR509 and HT-RC360. Any opinions on those or other recommendations?
TK423 is offline
post #2 of 5 Old 01-24-2013, 10:12 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
Pioneer 1122 at $359 on amazon. $344 on onkyo 616. Dont get 515. The 616 has much better features and price are almost the same. I own a 515. No issues so far. Get the 1122 if you can. Trust me.
javygonx is offline
post #3 of 5 Old 01-24-2013, 10:17 PM - Thread Starter
TK423's Avatar
I thought the Onkyo TX-NR616 had the same HDMI board or something as the 515 and therefore most of it's HDMI problems and unit failing?
There's a pretty extensive thread here just dedicated to issues with that series of receivers. The only reason I'm leery.
TK423 is offline
post #4 of 5 Old 01-25-2013, 08:09 AM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
Thats correct. I owned a 515 in which I sold it to my co-worker and so far is working great. I knew the issues but either way i bought it. I dont think all 515/616/717 models comes with this issues!!.. Issues started when receiver was released; I beleive Onkyo fixed most of the issues; plus there's a Firmware upgrade too. Your budget is $300; so for $60 more you can get the Pioneer 1122; better built quality; great sound and performance. You wont be dissapointed.....
javygonx is offline
post #5 of 5 Old 01-25-2013, 09:02 AM
afrogt's Avatar
Quoted: 1438 Post(s)
Liked: 982
afrogt is offline
Onkyo Tx Nr515
