Need help connecting a Passive sub to my Denon AVR-2112CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-24-2013, 07:19 PM - Thread Starter
smachine's Avatar
I have a built in 6.1 setup at my new house and got the 6 speakers connected to my Denon AVR-2112ci but had no idea how to connect the sub. One set of the zone 2/rear Left back surround speaker plugs is left empty on the receiver. The sub is built into the wall and I wanted to know if its possible to skip getting an external amp. The ends of the wire is white, green, red, and black which I assume mean its a nonpowered sub. Thanks for the help in advance, and I am a total noob at this stuff!!!
Here is pic of the back of the receiver: http://usa.denon.com/Assets/Images/products/AVR-2112CI/c26-avr-2112-2-l.png
Here is a drawing of the sub wire ends that come out of the wall: http://www.skycraftsurplus.com/images/products/detail/sk9243.jpg
smachine is offline
post #2 of 5 Old 01-25-2013, 04:09 AM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5503
No. Get an external sub amp as the AVR is not designed to power the subwoofer.
jdsmoothie is online now
post #3 of 5 Old 01-25-2013, 10:23 AM - Thread Starter
smachine's Avatar
Ok so external amp is only way? I read online that its possible to connect the sub wires to the front L and R inputs on the receiver and change the speaker configuration to large. Is this an option?
smachine is offline
post #4 of 5 Old 01-25-2013, 10:51 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
External amp is the best way. A $99 stereo amp/receiver can do the trick.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=252-125
http://www.amazon.com/AudioSource-AMP-100-Stereo-Power-Amplifier/dp/B00026BQJ6/ref=cm_cmu_pg__header
You would run a subwoofer cable from the Denon to the amp and connect your 4 wires to the speaker terminals on the back of the amp.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2680&seq=1&format=2
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=6261&seq=1&format=2
And if you do this, where would you connect the actual left and right speakers? If the passive sub was not in the wall and had speaker level outputs you might be able to do it. But since the speaker is in-wall, not really possible. Not the recommended way anyways.
Afro GT
afrogt is offline
post #5 of 5 Old 01-25-2013, 10:53 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Yes. The power to power the subwoofer's speaker driver has to come from some place and it isn't going to come from the AVR's sub outs, or the passive sub itself.
If you have an AVR with some spare back channels you'd have some power amps to reassign, but you would probably still be skunked because those spare channels are usually switched internally in very specific ways. This feature would make more sense than the current biamp wierdness.
Now, if you have an AVR with spare back channels and the AVR had preamp out/amp in terminals, you might be able to run a jumper from the pre amp out for the subwoofer to the unused back channel input(s) of those spare channels.
Back of your AVR:
Thing is, you don't!
You might want to read your user's guide very carefully to be sure...
arnyk is offline
Denon Avr 2112ci Receiver
