Phono input replacement board - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-25-2013, 03:05 PM - Thread Starter
muldoon's Avatar
Any suggestions about finding a replacement phonograph input plug-in board for an AVR 2807 receiver?
muldoon is offline
post #2 of 5 Old 01-25-2013, 04:49 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Why not just get an outboard phono. You have a wide choice at a price range from $50 on up. You can check Music Direct or Audio Advisor for a wide range of excellent phono's.smile.gif
Class A is offline
post #3 of 5 Old 01-25-2013, 04:50 PM
afrogt's Avatar
Quoted: 1054 Post(s)
Liked: 756
Have you tried contacting Denon support?
If unsuccessful you could try buying a new phone pre amp and using one of other analog inputs on the 2807
Afro GT
afrogt is offline
post #4 of 5 Old 01-25-2013, 06:29 PM - Thread Starter
muldoon's Avatar
Thanks for your reply. Denon has stopped stocking the part entirely. but I'll check into your suggestion.
muldoon is offline
post #5 of 5 Old 01-25-2013, 06:36 PM - Thread Starter
muldoon's Avatar
Thanks for your suggestion, but I not really sure what you mean (my ignorance, probably) I have a Thorens turntable, if that's what you are saying. I'm just trying to run all my analog stuff through the Denon in order to store it digitally. If you are suggesting another way to plug it in, I don't quite understand..
muldoon is offline
