Onkyo TX-NR609 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-25-2013, 08:36 PM - Thread Starter
cinobyte's Avatar
I think I have a grasp on how zone 2 works but the question i do have is.
If I have my media center connected with digital out to the TX-NR609 for normal 7.1 and analog connection from the same source with analog connection will I be able to play zone 2 or will the 609 always default to the digital signal and over ride the analog signal?
what I am trying to achieve
play the same source at the same time in two levels of the house. I know I can connect the speakers directly to the 609 but i want to be able to provide the speakers more wattage with a secondary amp hence wanting to use zone 2 output..
I hope that is a good explanation
Tia
cinobyte is offline
post #2 of 2 Old 01-26-2013, 04:30 AM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
For the main zone, the AVR will default to the digital signal; however, as Zone 2 can only play an analog connected source, it will be free to play that analog connection to Zone 2 without any interference from the digital connection while the digital connection is playing to the main zone.
jdsmoothie is offline
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver
