Help: HK 135 with popping channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-26-2013, 11:02 AM - Thread Starter
zachyahoo's Avatar
My Harmon Kardon AVR 135 is having issues with the right surround channel.
Our in-ceiling right surround speaker has been broken for a year or so, and I just got around to replacing it. Unfortunately, what I found when I did is that there was also something wrong with the channel coming from the amp.
The issue is a popping/clicking sound that happens every time the sound stops– either from pausing, muting, or just from a song ending.
Linked is a video of the problem in action.
My question is: Is this a problem that can be/would be worthwhile to be fixed? Who would I send it to? What would the cost be like? Etc.
Have any of you seen anything like this before?
Thanks for your help,
Zach
zachyahoo is offline
post #2 of 4 Old 02-09-2013, 06:24 PM - Thread Starter
zachyahoo's Avatar
Anyone have any advice?
post #3 of 4 Old 02-09-2013, 07:24 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
disconnect the existing speaker, get another speaker (any speaker), connect it with new wire as close as possible to the receiver (ie. use a short cable) and see what happens with the problem and go from there. IF you were running your rcvr with a "bad" speaker left connected, it is possible you have caused a problem with that amp section.
budwich is offline
post #4 of 4 Old 02-09-2013, 07:35 PM - Thread Starter
zachyahoo's Avatar
Budwich,
It's already been determined that the problem will follow that channel as I pass it from speaker to speaker. What is to be gained by this experiment?
Also, the other speaker's problem was caused by someone stepping on it – not the amp!
Thanks for your input though!
